Wow. That's not much power!? Must be a very conservative tune..
No.
From experience (ie been there done that) thats about right
could of leaned on it a little and seen 160rwkw's ish
BOS 3" split dump pipe 12rwkw
Catco Metal Cat 3rwkw
Trust Power Extreme 2 cat back zorst 10rwkw
K&N Panel filter 2rwkw
R34 Intercooler 0
GTR Fuel Pump 0
AFC Neo computer 15rwkw
SITC computer 8rwkw
say thats around 50rwkw in extra zoomph as a guestimate, add in the 110rwkw standard, at 10psi.............
nice safe tune and a conservative power reading is better then 15kw higher and leaning on the engine.
my 2c
bet it feels nice to drive hey !!
nice work, enjoy it
Tune is as I expected too, minus the SITC so could get up to around 160 if pushed it. I will get a FMIC eventually no doubt anyway.
It is very nice, I even had to 'rush' to work as the exhaust install took longer than expected. A nice excuse to open it up a bit :(:P
There are so many speed cameras on Sydney roads though .. hope I didn't make a donation, spent enough today already !
OK, the results are in and the winner is .....
Tangles :(
Max power 152.9Kw at the rears running just under 10psi. This is a Series 1, not neo motor by the way. And an auto :P
Goldzilla ... sorry I missed your post as my PC at home is dead and I went down there first thing this morning. Is yours the green one coming in for a 'trial fitting' next week ?? :)
Speaking of fitting, the Power Extreme cat back zorst needed a fair bit of manipulation to line up unfortunately. I guess that is the price of mixing and matching local dump pipe and cat with jap exhaust. A word or warning for others I guess, the BOS dump and Catco cat may not line up exactly like factory
Hey Stu, nice result. No worries about meeting up this morning, it's all good.
Yeah, that's me getting the trial fitting done on my car - I've got the JustJap combined split dump/front pipe going on mine, and seeing as a few people have had some issues getting theirs on their cars, I figured I'd best get them to do a test-fit first so I can either get a refund or sell it if indeed it doesn't go on.
I'll be getting a baseline dyno run done first, then if all goes well, the new dump pipe will be getting drilled for an exhaust temperature probe to be fitted, then the install, then a quick run on the dyno again to see if any gains have been made.
I'm not really expecting much of a power gain, as I haven't yet got any way of tweaking ignition, fuel or anything else. All my car has is a 3" cat-back exhaust and a manual box (which should provide a minor gain in itself due to slightly less slippage). If I get improved response, then I'm quite happy for now. Suspension tweaks are next, then the hunt for an FMIC and computer.
The boys there are very helpful and professional, so they won't BS you if it doesn't look like it will fit.
The muffler shop had to heat and bend the BOS dump a little to get it to fit also, plus the flanges on the catco cat are a little off and it has a small leak. Shows that nothing is perfect out there unfortunately, especially for stageas :thumbsup:
well thats definately one thing Im not entirely sure of (never driven a manual rb25det)
but its a theory I work towards.
ie my Stagea at the moment has say 195rwkw (was 190 @ 14psi with restictive muffler at last tune), if it was manual I have no doubt you could add 10rwkw to that and boast it had over 200 at the rears.
my next tune in 2.5 weeks time @ 16psi should net around say 210rwkw, surely thatd be more towards 225-230rwkw with a manual ? dunno, but thats what my readings on this site suggest.
* tips hat
* munches on jellybeans
* farts, oops sorry did I type that
For those interested, the difference between awkw and rwkw (with the front shaft removed) is ~20kw.
This was on 2 different dynos so give or take 5kw or something...
It helps to know when comparing power/weight ratios with other rwd cars. Also in the stagea's favour is the excellent 1st gear ratio (even in the auto) and 4.3 diff ratio, = great acceleration off the line, at the cost of fuel economy. Of course you cant compare cars perfectly this way but it is a (very) rough estimation...
And for what its worth, its also been proven that the Stagea will be quicker in AWD mode than in RWD with the front shaft removed, despite the higher kw reading for RWD.
So I'm guessing a RWD-mode stagea (assuming same weight, which RWD-only stageas aren't...) with 200rwkw would be a close match for an AWD stagea with 175-180awkw. Not taking the driver into account - this is just purely about comparing power outputs of similar cars.
None of the above can be used as a strict conversion, but it is a fairly close estimate IMO. :bunny:
None of the above can be used as a strict conversion, but it is a fairly close estimate IMO. :rolleyes:
it's exactly as the thread title states: Bingo. It's useful purely as a guage of %power increase provided you stick to the same dyno. It gives you an idea, but no dyno reading is definitive.
Alright, I had mine in on the dyno at Unique today, and confirmed that the JustJap combined split dump pipe and front pipe does NOT fit, which was rather annoying...
Who wants to guess how much my output was? It was leaning out up high when the high boost kicks in around 5,000rpm or whatever...
mod list plz?
:blink:
118rwkw?
Hmm, Major Tangles, there's not much to say here.
  • Manual conversion
  • 3" cat-back exhaust
  • R33 series 1 (steel compressor wheel) turbo, which was a drop-in replacement for when I blew my turbo back in November '05
...and as far as I know, that about covers the mods. I haven't actually made any performance mods to it since I bought it back in October 2005.
Any other guesses?
137.43972
I'm guessing none of the boys told you anything, Andrew? I was gonna exclude you from guessing, because I thought you might have seen/been told of the results.
Nice result for yours though! :blink:
Hmm, I was expecting 125-130rwkW,
It was...
:rofl: It had me stunned too! Lean-out power FTW! But risk of melted pistons (or worse) FTL!!!
New fuel pump coming up in a few weeks, and until then it's cruise, no major loads, and no big revs...
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
