>>> Drift Skills Hits Calder Park Aug 25th, Beginners Skills Day <<<
Want to learn to drift?
Kind of know how but need some tips?
Would like to give it a shot for the heck of it?
Need a break from grip racing?
Hellooo SAU peoples, Chance here from next door at nissansilvia.com getting the word out that this SATURDAY August 25th,
The Vic Drift Club and Calder Park are hosting a "Learn to Drift" Drift Skills day and we still have a few spots left!
We have 5 of Victoria's best Drift Australia Pro Drivers there to teach you hands-on in 5 different skill areas, to get the basics
of drift under your belt, so you can hit the track and become a fully fledged Drift King in no time!
It's an all day event, cost is $170 which includes lunch, call Calder to book your spot now, fuel up ur car and get down to the
Thunderdome this Saturday!
Any questions? CLICKY HERE or Call Calder. :D
Cheers - Chance :)
BOOK NOW!!! - Only 5 days away!!! Spots filling!!!
What else do we ned to bring other than petrol and car??
Will we need spare tyres? A Jack etc?
I dont wanna load up sh1t I dont need to bring...
I read on NS that tyre fitting will be avaiable...so I'm guessing we need tyres... ?
If you think you're going to get thru a set of tyres, by all means bring spares, and the tools needed to change them, jack etc.
You will also need to wear long pants and long sleeve top.
See you there!
Cheers - Chance :rolleyes:
Got an E-mail from calder today...
Said to bring some tyres so all good, free tyre changing on the day...
THere'll be 2nd hand tyres for sale too
Can' wait should be fun... :3some:
What did you think of the day? you certainly had no dramas in our section.
I had an absolutely awesome time!! Would definately recommend anyone to go the the next one. I learnt heaps and you could notice the improvements in everyone as the day progressed.
And the instructors and DA drivers were all super nice!
p.s.
Anyone come accross a small gray cardbored box with "WORK" written on it??
It contains some locks nuts, some normal nuts and most importantly my lock-nut KEY! I cant get my wheels off without it and all 5 studs per wheel are lok nuts so will cost me a bomb to get them bashed out :(
I rang calder but they didnt pick it up, hopefully someone here picked it up :)
Thanks!
I'll offer a $50 rewards if it helps. :)
Guest
    • As I implied in my post, I have NO idea what the were. But in case I didn't make it clear, the way they performed was brilliant; whatever the brand was. I think it was the compound that made the difference. And if they were Bendix, then sign me up, I want another set. I did drive down mount Ousley (just outside of the Gong) a few times, and they showed no untowards performance.   Its not the low dust that I am looking for NOW. At the time I needed low dust, but now I have no issues with dust but want the initial/early bite of the pads that were used. Yeah, the early cold squeal may of been due to a missing shim or such.  And to repeat, its not the low dust I am seeking, its the initial bite of the pads and increase in bite as  the warmed up during each breaking. As soon as I let off, I don't remember the breaks being extra sticky if I used them again soon after. But I also did not test that theory.   Thanks for the recommendation, But I would prefer to choose something specifically with the behaviour I described.   I assume that they didn't use the default compound off the shelf, as we discussed the dust issue at length. And the early squeal when cold, I have seen the sound is more of an issue with some pad compounds. Mostly ceramic, which also are said to produce less dust.
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
    • He'll be looking down and swearing about "the damn apprentice" for trying to convince Duncan to use percussive maintenance... 😛
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
