Does anyone have a pic of the boot, with the floor panel opened?
What is under there? Is it just a spare wheel? I'm planning my stereo at the moment and I still don't have a Stagea. I'm looking for somewhere to put a sub, as I don't want a box in the back. I'll be chucking mountain bikes in there every weekend so it's important that I have as much room as possible back there.
So.. Does anyone feel like taking a pic for me? :)
https://www.sau.com.au/forums/topic/181607-photo-of-the-boot/
I don't have any photo's but you may be pushing shit uphill with a thin stick my friend. The spare wheel is a space saver so the well isn't that deep, and the panels on either side just cover the top of the fuel tank (the one on the drivers side covers the access to the fuel tank cover) . The best thing I can suggest is that you try and make use of the room between the rear strut uprights and the back of the rear seat. It will be about the only way you can do it and still be able to chuck in large stuff like bikes etc. One of the many joys of sharing the skyline floor pan.
yeah.. i have been looking at this as well .. and to make a completely " stealth " install is going to be hard. Why not try and mount the amps under the front seats if possible.. then just put the speakers in the standard locations.. and just unclip the sub and take it out of the car when need be?
and yeah.. you can get those very shallow mount subs ( from pioneer if I remember correctly )
there IS one little sneaky compartment to the left hand side of the cargo area.. and if you got a really small amp you may be able to house it in there and keep everthhing out of sight
Just a tip - unles you have a passionate fetish for replacing the gas struts, do NOT put anything heavier than a 6" speaker in the tailgate. The bloody tailgate weigh's enough as it is :)
And if you do put speakers in there, pleasepleasepleaseplease make sure you really solidly mount them because in the case of getting rear ended, they will turn into a rawther nasty projectile......
IMO the compartment you are talking about wouldn't be anywhere near enough air to mount anything other than a free to air sub and they suck.
  Stinky Rooster said:
Just a tip - unles you have a passionate fetish for replacing the gas struts, do NOT put anything heavier than a 6" speaker in the tailgate. The bloody tailgate weigh's enough as it is :laugh:
Shameless plug: I actually have a dozen 6" subs available for sale... Seriously.
That aside, where there's a will..... Small subs - a pair or two, in separate sealed enclosures.... easier to fit, just a pain in the rear end to install. I have seen a wagon with a pair of 8" subs mounted at the top of each c-pillar. Remember, too, that bass is non- directional, so you can mount subs wherever they will fit, irrespective of which direction they face. Behind the dash, above the passenger footwell is a favourite of mine. It just depends on how far you want to go, and/or how much you want to compromise on practicality/room. Just my opinion is all.
Low frequency sound waves are big and long so the further away from the passengers you can mount them, the more time you have for the sound wave to develop properly before it reaches you. Thats why all the high end installs have the subs as far down the back as possible. Its not a bad idea to stick little ones all over the place, but you have to remember that below 10" the smaller the diameter, the more low end accuracy you lose.
If it anything like the r34 space saver you can make a 45-50L enclosure with it, inverted sub of course .. with the sub in you can put a medium level sub in and have a sealed enclosure .. hope that helps .. tested it myself :thumbsup:
  rb26stagea said:
spare in a can
true that
i have been thinking about this sub-ject to. and i have come up with the i dear to make the entire boot a sub inclosure. (as small as possible of corse) covering the entire floor. then put perspex over the subs so you can still sit stuff on top of them. i want to be able to have the subs in and still sleep in it. due to some calculatins i think i can do it with only using 150 mm high of boot spacecover the entir lot.
Inside the trim on the LHS of the boot there is a fair bit of space as the little storage pocket actually unclips from the back of the trim and there is more room either side and below it so you could probably hide an amp in there no probs you would just need to fabricate a bracket for it and if you were using fibreglass and were ok with the box coming out as far as the strut you could build a reasonable size box for a single sub as well
still makes me laugh that we are discussing stereo installs to take the least amount of room.. and we all drive these wagons with massive storage in the back haha .. but yeah I too want to keep it looking factory when our stereo install has been done
I agree Dale, but then again there's no use having massive load space if it's not available to use. Two weeks after I got my car back in '05, I made two trips to the airport to pick up relo's from overseas. Even the space behind the rear strut towers gets used if you have a large enough load or lots of things to carry, so I'm only willing to give up one side of these when I eventually have a sub installed in the back.
Stealth FTW, right?!?!?!
    • This is awesome.
    • Thanks for the quick replies guys its appreciated. A small extension was welded onto the standard 6boost external gate pipe which you can see where the pipe goes from black to stainless just below and to the right of the rear housing in the first picture. Overall I would say the flow is pretty good other than 6boosts choice to come straight off the collector at a decent angle.. Not sure why I went with two valves, I originally replaced the stock twin bovs with the GFB when I had the twins on. When I purchased the EFR it came with the Turbosmart Kompact BOV so I figured that would be a better option than the stock EFR Bov. I don't believe the Turbosmart BOV is adjustable? When I get the spike and then sudden dip in boost pressure, the turbo speed does drop as well. Stock head size wise however I believe it has Neo Turbo springs and a Neo Turbo intake camshaft and an aftermarket exhaust camshaft in the vicinity of 260 degrees. We didn't try a different MAC valve, we tried two different ways of plumbing it and we also tried removing the mac valve entirely and just having the boost source from the turbo directly connected to the wastegate and it still spiked / dropped and exhibited the same behaviour. Standard R33 GTR 5 speed tansmission. I'm running a Haltech Elite 2500 and can provide some logs if you. I understand what you're saying in that it looks like an auto plot however no, it's still a manual and it just has a lot of torque down low, for all intents and purposes it's a very impressive street car. I've attached a photo of the quickbitz dyno plot which was when the only difference is I was running -5 twin turbos with a mac valve. As you can see theres a decent dip in AFRs between 125kmh and 135kmh. Our problem now is not that the AFRs are dropping, just the boost pressure is dropping, however it is evident in the same RPM range of the map, coincidentally or not.
    • What transmission are you running?  It's a bit tricky with the scaling, but at face value the power "curve" looks more like a "line" which is a bit odd... basically a lot more like a dyno plot I'd expect with a highish (compared to a factory auto) stall torque converter type setup. If this is running an auto then this kind of boost control challenge is definitely a thing, the rpm scale on the dyno doesn't reflect what the engine is actually doing (unless the dyno has access to the engine's ACTUAL speed electronically) and what you'll get is a big rpm flare up as the engine torque launches past the converter pump's ability to resist torque at that rpm, then as the converter starts picking up rpm it will kinda even out again and the engine rpm will pick up more steadily. The trick with this "flare up" is if it's kinda near the boost threshold for the turbo then the engine's airflow requirements to maintain the previous boost level will outrun the turbo's ability to supply that boost - so you end up with a natural flattening off, if not dip when that happens.   If you are running closed loop, or even tune the "feed forward" wastegate duty cycle to deal with that rpm spike then when the engine starts settling to a more typical climb you'll actually have a situation where the gate is "too closed" and boost will run away for a bit, then have to pull down again.      It's not trivial to get this perfect as most boost control systems are generally expecting more predictable engine rpm rates of change, but if you *know* that's whats going on then you can at least "accept your fate" and realise getting that area perfect is kinda chasing your tail a bit, and assume that if the rest is working sensibly and the spike/dip isn't completely uncontrolled then you should be good. Sorry if I've gone off on a tangent, but the dyno plot and boost control behaviour look a LOT like what I've seen tuning autos in the past. What ECU are you running? Could possibly be convinced into looking at logs if I get too bored this weekend haha.
    • A few things that seem a bit off here. - why is there 2 BOV’s?  - the turbo smart BOV on the compressor housing, is it turned up ALL the way? I have seen this become an issue on old man Pete’s car. It would push open and recirc, turbo speed would rise and the boost pressure would do weird things. - stock head? Does that include springs? - tried a different MAC valve? Is it plumbed correctly?
    • Photo of manifold showing gate location? I mean, it's 6Boost, so we probably shouldn't be worrying, but always wroth knowing what the layout is. Plumbed back to atmosphere? Or into the dump?
