30 block are cheap as.
but i would like to know the ans to this question also
is it due to the longer stroke which can smash the piston into the valves???
and how high would the head need to be raised to prevent this?
the tomie rb30 uses the 26 block with 3.0L crank so why isnt this possible to do yourself???
Edited by humz
hhmmm, interesting. Keeping an eye on this thread.
Have a look about 6 months ago.
Guy did it, wouldnt go into much detail so its safe to assume one of two things
1. He was talking shit
2. Is cost a lot of time, and money and probably isnt worth the effort
Plus, when a 26 crank works just fine, not sure why you would bother
As you know I want to but RB30 Crank because it has longer Stroke is more than RB26 Stroke, I mean if I can use RB26 Conrods because it's short and I think it will give me more renovation.
Edited by Supra2000
I think these forums need to be IQ means tested.
Lets look at the stroke of the following
rb26 86 x 73.7
rb30 86 x 85
Now thats the stroke - thats the distance the piston travels from the bottom of the bore to the top of the bore.
So the Rb30 travels 11.3mm overall more - divide that by 2, as half is at the bottom and the other half is at the top - so from basic maths the rb30 stroke is 5.65mm more than the rb26 at the bottom and at the top of the stroke.
So if you were to install a RB30 crank into a RB26 block, you would end up with a stroke that sticks the psiton 5.65mm higher than the RB26 crank - now this couldnt be good for your piston to head clearance.
So you would either have to use a custom piston or a custom conrod to make this work.
It would be a lot cheaper and easier to buy a RB30 4wd adaptor plate and bolt that in your GTR
    • On the hot side pipe work, or if you want to compensate for pressure loss from the IC, post intercooler on the cold side, pre-throttle
    • They're notoriously difficult if you traverse forums... the 102TB and FAST102 are so bad that most people actively don't buy it unless they REALLY want that extra 1hp. The idle stuff isn't really that hard. The cam is pretty manageable and while it acts like a larger cam the whole car actually drives smoother than before. I like to just tinker so if I can get 50rpm less variance or rule out situations where it does 'unexpected' things it's fun for me. HOWEVER If you just let a tuner give it a guess for a couple of hours and had no way/desire to test and tweak it yourself you'd spend a lot of money at the tuner or be pretty frustrated, that's for sure. But yeah. Drives great. (then I drive partner's Civic Type R and I think.. well, more tweaking to do) But for what it is (cam, TB, intake, manual etc) it does commute around really great once you figure out how the idle tables and GM's systems intend to work.
    • I usually source pressure on inlet manifold after throttle body
    • Where is the best location for boost pressure source when running mac 3port boost solenoid?  my new turbo does not have a fitting for that on the compressor housing.  how come Garrett make a turbo without that?  im confused
    • From my memory, which isn't that great, we did have issues getting the large throttle body on my old LS1 to play nicely at idle, first it would stall, then it would only idle at 2k rpm, then it would hang at 2k rpm for a few seconds and then drop and stall, then, finally, the best we got was it would hang at 1.5k rpm for a few seconds then drop to around 800 rpm The tuner stated that large cable throttle bodies are a PITA, and if I wanted anything better than what we ended up with I would need a electronic throttle body and all of the aftermarket ECU stuff to run it
