evenin folks,
hoping this thread will be slightly more successful then my last one (even though that was a laugh for the most part).
im looking at organising a paintball day sometime after september (gonna be a busy month at work), so probably around late oct/early nov... or whenever's good for the majority.
thinking of making the booking at 'paintball park' in elizabeth.
been there a couple times, staff are a load of fun, the equipment is always in good condition, ammo's cheap as chips ($140 for 1000 :angry:), and theyre constantly expanding the playing areas.
the more the merrier (aiming for 40+), so if youre keen, ask your mates, and get them to ask their mates, and so on and so forth, lol.
if i get enough interest, ill start making all the arrangements in the next couple weeks.
deposits of $20 will be collected soon after.
thanks,
dave.
and fellas, remember to bring $5 for a cup, its damn good insurance. :thumbsup:
ok, so whos in? weve got so far;
me (+ 1 (maybe +7 thus far))
dangerman4
rad 33
nos man
heslo (+ 3)
sinistagtst
nightcrawler
lunaticR32 (+ 1)
Tuffr32
Da_Black_Wolf (+ 1)
dnbutts (+ 5??)
vietorious (??)
paulywhore33
barricade
25
once we get to 30 ill start with the bookings.
Edited by scandyflick
https://www.sau.com.au/forums/topic/181659-eoi-paintball/
evenin folks,
been there a couple times, staff are a load of fun, the equipment is always in good condition, ammo's cheap as chips ($140 for 1000 :thumbsup:), and theyre constantly expanding the playing areas.
thanks,
dave.
hey Dave
let me know once youve got the numbers together and i will book it.
that way i get the free 1000 rounds....
cheers
https://www.sau.com.au/forums/topic/181659-eoi-paintball/#findComment-3299239
here we go with the northern bashing :thumbsup:
for those that havent been to paintball park, there IS an enclosed parking lot, that is within sight of the break area. so your cars should be safe.
https://www.sau.com.au/forums/topic/181659-eoi-paintball/#findComment-3299264
thats a point.
but safety in numbers i reckon.
how many skyline thieves are there?
if theres 30 cars, surely they wont all get flogged.
maybe one or 2 that turn up late and park on the outskirts of the car park, but the rest should be fine.
https://www.sau.com.au/forums/topic/181659-eoi-paintball/#findComment-3299281
so how much roughly is it each? we gota buy 1000 balls do we? never done paintball before, ill prob be keen
go team old school's
can we ban those army commando guys though :thumbsup: , that’s just an unfair advantage
its probably best to budget a couple hundred bucks, especially if we make a good solid day of it.
basic pack is $35, this gets you;
100 paintballs.
Tippmann 98 semi automatic paintball marker hire. (Extremely reliable and easy to use).
20oz CO2 bottle hire. (800+ shots).
FREE CO2 refills all day.
JT Mask hire. (Fog resistant lens & chin strap).
Camouflage overall hire. (Padded neck, throat & back of head protection).
FREE padded vest hire. (Protects front & back).
Safety speech / briefing.
Marker (paint gun) briefing & practice.
Referee/s assisting your group at all times on the playing fields for safety, assistance & coaching.
FREE BBQ facilities (Arrange before the day of play. BYO food, utensils etc).
Half or full day field use.
NO extra cost to play all day!
extra ammo is;
100 paintballs $ 20 ($20 per 100)
300 paintballs $ 54 ($18 per 100)
500 paintballs $ 80 ($16 per 100)
1000 paintballs $140 ($14 per 100)
i tend to go through atleast 1000 per outing (but im trigger happy on prozac... and i plan on breaking the record this time)
but 500 should suffice for most people.
its good fun, you wake up a bit sore the next day, but its all worth it.
its fairly close quarters stuff, so the commando advantage is pretty small :angry:
https://www.sau.com.au/forums/topic/181659-eoi-paintball/#findComment-3299298
Never been before so count me and Bek in!!
Dan should be disqualified...or have his rifle bent a little as a handicap.. :thumbsup:
dont worry, he'll have something special organised for him :angry:
lookin forward to seein ya there :P
https://www.sau.com.au/forums/topic/181659-eoi-paintball/#findComment-3299433
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
