As stated I have a 1997 Nissan skyline series 2 r33. Silver in colour.
The car is in immaculate condition inside and out with not a single scrach on the body(never been resprayed), it will not dissappoint. I have personally owned the car for about 2.5 to 3 years now and it was completly stock when i purchused it. All modifications have been done by protek automotive from day one, with me forking out my hard earned dollars, with most mods only done in the last 8 months i.e turbo, plenum, cams,injectors. (i caught the mod bug bad)
the car has 110,000km's on it. these are true km's not just another dash whacked in there which most people do. When you think about it its not bad at all for a 10 year old car. I have never had one hint of trouble with this car except fot the starter motor going about a month ago which was replaced with a brand new one. I have recipts for all work done to the car, all in all adding up to over $20,000. The car has never seen a track day or drift event.
The car currently makes 255rwkw's on 16 psi (with dyno sheets). All the car needs is a 35-40 or bigger to unlock its full potential which was my next mod (i am told it will easily make 310 plus rwkw) , but due to getting more serious with my working life i have brought a ute. I dont want to sell my pride and joy but it really is unrealistic to have two cars esspecially as i have barely driven it since buying my ute. I have tried to keep her.
SORRY for the long comments but the car really is worth it.
List of mods as follows:
ENGINE:
apexi power FC
hi flowed turbo (450hp)
custom SS 3in exhaust from turbo back. (with hi flowed cat)
custom made Plenum by CPC (custum plenum creations)
80mm billet throttle body
Tomei cams
hi mount ss manifold (not yet fitted)
550cc sard injectors
boosh 040 fuel pump
hybrid gt spec FMIC
Z32 air flow meter
OS gieken cam gears
alloy catch can
brass button motor sport clutch (good for 300plus rwkw)
lightened fly wheel
blitz pod filter
Front and rear strut braces
All brand new hoses and lines on plenum side if the motor due to the size of the plenum including gtr radiator hose etc.
always used motul oils
sevice at least every 5,000km's
INTERIOR:
Apexi AVCR black edition
Blitz FATT turbo timer
Auto meter colt gauges (boost, oil and water temp)
alpine head unit (not sure of the model but its good)
focal front and rear speakers
two alpine V12 amps
Alpine type R 12IN sub (removes in about 1 min)
nismo gear knob
EVERYTHING ELSE:
Tein fully adjustable coilover suspension (fronts just rebuilt by fulcum 2 months ago, done about 500kms)
tein adjustable castor rods
19in starcorp fusion wheels (much wider at the back but i cant remember exact dimensions)
hankook K104 rubber (245 front, 275 rear)
nismo clear side indicators
12 months rego paid today 20/8/07
I know there is more but the cars in my parents garage so this is all off the top of my head.
I still have nearly all of the standard parts which you can have
I am asking for $19,000.00 ONO - With ALL standard parts.
Car needs to go.
*Please Note; Due to minimizing Pixels in images. Images may seem distorted.
This car really does speak for its self. drive it and you will be sold.
I am located in the SE suburbs of melb
All enquires are welcome.
contact me via
mobile- 0413068555 (my name is Dan)
email- [email protected]
THANKS for you time guys. DAN
Edited by DNR33
    • If the RB29 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
    • Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
