Bought brand new from NISMO. Done about 1500kms. Seriously.
As new condition.
Part no. 3003A-RS592
PUSH type Clutch for R32 GTS-t, R33 GTS-t, R32 GTR
$2500.
Contact me: andrewho at viriumgroup dot com
https://www.sau.com.au/forums/topic/18167-nismo-triple-plate-clutch/
And i thought my twin plates were awesome!
Too expensive though!!!!!
Holy shit that is one beast of a clutch!!
BUMP for that!!
Oh yeah, how did you attach images to your original post merli? I canot find a browse button anywhere when i make my first post, i can only add pictures when i reply to my own threads, does that make sense?
Lepperfish: Removed from the car after 1500kms because I'm selling the car. They would be over $4000 if you tried to source one from an Australian distributor. I bought it for Jap retail plus $300 shipping, and it came out to $3100. No lies. Straight truth.
BNR32: expensive?? Are you serious? This clutch is literally brand new (the clutch plates aren't even worn in yet), and it's about $1500 cheaper than you'd get from Australian NISMO distributors!!!
To post images like I did, you have to host the images yourself, and then use the img tags:
e.g. [ img]http://www.dummy.com/photo.jpg[ /img]
  • 3 weeks later...
Bro will be interested in sending the set of clutch overseas (singapore) ? How much would the freight be and also r u willing to negotiate the price a little more say anything up to 20% ?
I can organise freight to Singapore no problems... I have no idea how much freight would be...
[email protected] to discuss the price, but no, If you want a $2000 clutch, this isn't the one for you.
    • Result of another R35GTR build. Similar specs as above except this is running our bigger size SS-2 profile option. Made similar power except this car runs on Pump 98 fuel. Build specs are: Nissan R35 GTR 2015 model stock engine and box. ETS street intercooler boost logi intercooler piping with tial bov, boost logi turbo inlet pipe ID 1050 injector DW 300C fuel pump Decatted oem down pipe and y pipe& HKS exaust 3inch intake pipe Upgraded actautors HyperGear SS-2 high flow option Final result is 639whp / 477wkws hubs, Ron 93 / P98 fuel at 20psi.
    • Duncan:- it affect both sides.  Driver side is worse.
    • That seems like a very special issue!  Does it affect both sides? Either way, I would disconnect the driver's side switch and see if it still happens, noting that might require removal of the whole door card which is a bit of a pain (it does on V37 and HY51)
    • MBS206:- The windows start to slowly open themselves. GTSBoy:- Battery is new since Dec.
    • I currently have a 2008 370GT Coupe, with the big brakes (Akebeno if I'm correct), and Its coming time to get new pads. Previously, I had a 2003 350GT Coupe with the stock sized brakes, not Brembos. I had custom wheels on it that were pretty open to the brakes, and when I first put the wheels on it, the rims where completely coated with brake dust. A few years after adding the new rims, I needed to change to pads on that car. I didn't do any research, but I told the mechanic of the problem with the brake dust. I also told him I didn't track the car or even drive around the streets harshley. But the dust was an issue. The mechanics changed the pads to a different compound, and the dust was GONE! The other change I noted was that when coming to a complete stop, instead of having to press harder on the pedal as I approached 0kph, I had to actually lift off a little to not come to a hard jerky stop.( My unfounded explanation is they became stickier as they heated by stopping ) Since I got my 370gt with big brakes, I noticed that that as I came closer to stopping, I had to press harder and harder to reach a full stop. I am not talking about hard, just harder. I brought the car in from another state, so when I had a blue slip done, I asked the mechanic what he thought of the brakes, and he thought they were brilliant. The only negative of these pads on the 350GT, was that they squealed when cold. So driving out of a shopping center carpark, it was a little embarrassing, as the brakes squealed, and I am sure people thought that I needed new brakes, when they were actually fresh. I have no idea of what type of compound they were on the 350gt, but whatever it was, I want to get the exact same on my 370GT. They weren't ridiculously expensive, and were replaced at the local JAX (which is no longer open), so I am certain they would be a pretty common big brand, off the shelf type/brand. My current mechanic suggested I need top get the rear pads changed soonish, but he suggested standard Brembo pads. Which I expect to behave the same as the current ones and not like the ones on the 350GT.  I don't think dust will be an issue on the 370GT. With the behaviour I describe above on the 360GT, does anyone have a suggestion of pad material that will act like the change I had done on the 350GT?
