Have unfortunalty done the sums and cant afford the GTR 33 i was looking at so to drown my sorrows im thinking of upgrading my GTST series 2 33 abit....
My mods so far include -
- Power FC & Controller
- Fuel Pump
- Full Turbo back stainless steel 3inch exhaust
- big front mount
- pod
- new big radiator
- just over 200 kws at the wheels.
I was talking to shaun at boostworxs and he says with the current set up has pretty much maxed out the turbo...
So im looking for a new turbo. I dont wanna spend a fortune, was looking at slides turbos but i reali want 275 or closer to 300kws at the wheels and i dont think they will cut it....
Its a daily driven car so i want minimal turbo lag also....
Any suggestions?
Ill also get 555c injectors when i get the turbo probably deauchwirks ones
anything else i have over looked that i should upgrade??
Thanks
Adam
Edited by Adz2332
https://www.sau.com.au/forums/topic/181715-275-300kws/
afm, clutch, flywheel, possibly coils, and alot of people will suggest suspension.
personally i wouldn't put stock internals through more than 260ish
Edited by joeyjoejoejuniorshabadoo
https://www.sau.com.au/forums/topic/181715-275-300kws/#findComment-3299978
very expensive.....thats why im selling up and bought a 32 gtr
haha yer i was thinking of doing that and go to a GTR 33 but cant quite afford it... And i think the 32gtrs are getting abit old... dont want a heap of problems
https://www.sau.com.au/forums/topic/181715-275-300kws/#findComment-3300011
When the new turbo goes on in a month, i'm not going over 260, although i probably wont be able to get her much further anyway on a gtrs setup...
250 to 270 seems to be the accepted limit round these parts...
https://www.sau.com.au/forums/topic/181715-275-300kws/#findComment-3300015
cheers for that
https://www.sau.com.au/forums/topic/181715-275-300kws/#findComment-3300035
whats a standered GTR r32 run in kws?
kw only tell part of the story - even R32 GTRs are a LOT heavier than the 25t, so that effects power/weight and the fact that the engines are similar size means there is a huge difference in the effective power delivery. I am running pretty much the same turbo on my 25 as Cubes is and I haven't been in a GTR running stock twins that pulls as hard as my 25t does.
https://www.sau.com.au/forums/topic/181715-275-300kws/#findComment-3300138
damn this is hard and a confusing decision......
i like the idea of awd and the fact its a gtr...
i want the fastest car i can get in the 1/4 mile, and i have the choice out of around 220kw gtr or around 260kw gtst 33...
https://www.sau.com.au/forums/topic/181715-275-300kws/#findComment-3300195
In my opinion a 260rwkw GTS25t on a set of MickyT ET Streets would rape an 220wkw R32 GTR down the 1/4.
https://www.sau.com.au/forums/topic/181715-275-300kws/#findComment-3300491
i have the same problem, the gtr is superior in every way to the gst-s rb25. i want a gtr, so to kill that urge ive just got a hks gt30r stuck on my gts-t r33. apparently they pulled over 300rwkw with mine, but il be limiting that to 270-280. obviously the complete fuel system is upgraded ect.
https://www.sau.com.au/forums/topic/181715-275-300kws/#findComment-3301190
yer i dunno im leaning towards to the gtr 32
https://www.sau.com.au/forums/topic/181715-275-300kws/#findComment-3301278
yeah i love the look and the performance of the 32 gtr, it seems like its 15-20years ahead of time, but it seems to hard to find one that hasnt had the absolute crap thrashed out of it. im sure there may be some decent ones out there. all the best with the 32 search. i would swap my car for a decent 32 gtr any day.
https://www.sau.com.au/forums/topic/181715-275-300kws/#findComment-3301775
Hey ADZ
I just completed my upgrade.
I was able to get 261rwkw without spending 4k for a turbo.
This is how I look at it.
Keep the GTST for a year or more and then trade it in for GTR-33.
The GTST will hold more value as a performance car then a 200KW car.
IF you own your GTST then just trade it now and get a loan for 15k to 20K.
https://www.sau.com.au/forums/topic/181715-275-300kws/#findComment-3301798
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
    • How complicated is PID boost control? To me it really doesn't seem that difficult. I'm not disputing the core assertion (specialization can be better than general purpose solutions), I'm just saying we're 30+ years removed from the days when transistor budgets were in the thousands and we had to hem and haw about whether there's enough ECC DRAM or enough clock cycles or the interrupt handler can respond fast enough to handle another task. I really struggle to see how a Greddy Profec or an HKS EVC7 or whatever else is somehow a far superior solution to what you get in a Haltech Nexus/Elite ECU. I don't see OEMs spending time on dedicated boost control modules in any car I've ever touched. Is there value to separating out a motor controller or engine controller vs an infotainment module? Of course, those are two completely different tasks with highly divergent requirements. The reason why I cite data sheets, service manuals, etc is because as you have clearly suggested I don't know what I'm doing, can't learn how to do anything correctly, and have never actually done anything myself. So when I do offer advice to people I like to use sources that are not just based off of taking my word for it and can be independently verified by others so it's not just my misinterpretation of a primary source.
    • That's awesome, well done! Love all these older Datsun / Nissans so rare now
