In my opinion a 260rwkw GTS25t on a set of MickyT ET Streets would rape an 220wkw R32 GTR down the 1/4.
Yeah i agree :action-smiley-069: What you really want a GTR for is the track, where AWD can suck up the corners. But doing 1/4 mile, you need those extra kW's in your tuned GTS-T.
if you get an R32 GTR, try to stretch your budget to buy one that has been rebuilt and has aftermarket turbo's/turbo.
you would be silly or all cashed up to buy yourself a $18K 89 model R32 GTR with original engine and turn up the wick on those..
how much money you got to spend?
if your car is worth $15K and you have another $10K lying around, you could get yourself a nicely built R32 GTR for $25K that only a handful of GTST's could come near in a straight line or around corners.
theres one im looking at with a gtr 33 engine in it...
afm, clutch, flywheel, possibly coils, and alot of people will suggest suspension.
personally i wouldn't put stock internals through more than 260ish
Brakes are usually a good idea at this sort of power level also. People often forget... it's all good to be making huge numbers but you need the anchors to stop the boat.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
