I've a set of 4 old style Enkei 3-piece rims with the black face and 7-spoke design with a polished rim.
they are all 17x8 inch in size yet one of them is damaged.
so now I'm after similar design 17x9 inch rims to fit on the back.
these rims are only for track use so I'm not fussed if they are completely different. as long as the offset is fine.
I don't really know the offset numbers but I'm after something that'll line up with the rear guards slight. maybe 0.5cm out would be nice.
I also have a pair of Simmons FR rims with Falken ZE326 tyres at 80% tread that I'll be happy to arrange for a swap or something. these are 17x8 in size and used to sit on the front. missing centre caps though. still in very good condition. just hardly driven on. they are 5 years old but only seen 6 months on the road as they have been sitting around at home.
I'm based in melbourne, westside (don't worry I'm not dodgy lol!) so I would prefer local pickup.
I will post up pics of the Enkei's soon to give you a better idea.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
