r33 gtst.
current mods
k&n pos filter with shield
pfc
fmic
ebc
turbo back 3inch exhaust, with hiflowed cat
slide hiflow
stock injectors
stock fuel pump
stock afm
(af ratios were 12/1)
Im making 209rwk at the moment on 13psi
what should i expect the power output to be with these extras-
16psi
z32 afm
500cc hiflowed injectors
tomei intank fuel pump
hks actuator
Thanks guys
https://www.sau.com.au/forums/topic/181753-how-much-power-should-i-expect/
http://www.skylinesaustralia.com/forums/in...showtopic=55845
This should help you out a bit.
Should be able to get between 240- 280rwkw on 16psi, depending on little things such as how healthy the engine is.
Thanks,
Abu
Edited by abu
Should be able to get between 250- 280rwkw on 16psi, depending on little things such as how healthy the engine is.
Thanks,
Abu
250-280 sounds abit high for 16psi on a hiflow.
R33 gts-t
apexi power fc
blitz frount mount cooler
nismo fuel pump
z32 AFM
AVC-R
Split dump pipe
Custom Garrett highflow turbo
Thermo fans
Stock internals
Stock injectors
256 rwkw at 1 bar
Will post new dyno sheet when I scan it in.
Thanks to Paul Fisher at Pulse Racing (Menai - Sydney) - Definately knows his stuff, i would not go anywhere else.
apexi power fc
nismo fuel pump
z32 AFM
AVC-R
dump pipe
NEW garrett highflow turbo (PM me if interested in this - avail. soon)
252 rwkw at 1 bar (14.5psi)
Hits boost nice and early and does not drop off.
Like I said, have a read through the link I provided. It is possible, depending on the little specifics, such as tune and engine health.
Thanks,
Abu
Edited by abu
Ɨ
Ɨ
