See at least when i was going like 200-300 ks a day when i first got mine (once again... not going anywhere in particular) petrol was around 93c for Optimax etc :action-smiley-069: so it wasnt too bad
Damn that must have been in the days!.. Not so cheap anymore :P
Personally dont mind paying up to $1.00/L for petrol, but anything more is just getting to be a rip off.
Edited by abu
Thanks guys :D
I'm already feeling the money thing. Gotta fill up again (50litres in 3 days :O) but i had to drive around to show my mates + uni etc. :) Its worth it anyway! Plus i bought the pod filter and some new speakers for it. Turbo timer next i think.
I keep trying to make eye contact with other skyline drivers to give a thumbs up etc. but no success yet :) I'm sure if it was one of you guys you'd return it!
Going from a lancer to a 32gtst makes it feel like a ferrari!!!
Makes me want a GTR even more. I took a girl for a drive today and she described it as faster than a roller coaster :yes:
Edited by Grinners
powerade still costs more than petrol..
no its not... i bought a 24 slab of it the other day $9... theyre 310m cans... which means that it works out at 37ish cents which means per litre its around $1 and seeing as petrol is 1.28, its more economical to bike to work each day and drink powerade to refresh and replace your electrolites then drive.
think about it
Thanks guys :D
Thats good to hear mate... just dont go driving it like it is a ferrari... dunno if uve noticed but most ferrari drivers cant actually drive. Plus the last thing we need is more hoon stories ;)
Hey mate,
Congrats on the car, I got my first car (R32 GTS) about a year ago now, probably the best decision i have ever made, take care of it and you can't go wrong ;)....however I'm a tad jealous of your turbo ha ha, i got mine NA cauz i was worried about the new turbo laws coming out, turns out i could have got one anyway but ahh well.....32-GTR is only a year away lol :sorcerer:
If your thinking about tinkering with your stereo check out my DIY thread on installing a sub and amp,
Have fun mate,
Best regards,
Sean
never seen powerade in a can.....
Dont know where you get your powerade..
Powerade/gatorade is usually like $1.50-$2.50 for 600-700ml (whatever size the bottle is)....
don't know where you get your petrol....
read in a wheels magazine, that petrol is at its cheapest ever when compared to several years ago.
The price of water, electricity, food etc has increased by a much larger percentage than petrol and is more expensive.
Article in December 2006 Wheels magazine :wave:
Congrats on your purchase?
Any pics yet?
What uni do you go to?
congrats man
i remember when i first got my 32
i posted up here in excitement and spent about 500 bucks on fuel that weekend
lmao
just take care of it, and definatly dont be shy to pull things apart and put them back (start of in the interior to begin with)
just good to know how to do stuff aswell.
also dont let everyone drive it
biggest mistake i made
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
