SOLD
Putting my 1999 r34 GTT up for sale/trade
* Auto/Tiptronic
* 150,xxx km (i did a $5.5k rebuild at 120xxx km using original (and very expensive) Nissan parts to condition the engine)
* Serviced every 5000-6000 km using full synthetic oil.
* Garaged every night
* Brant nemesis keypad alarm
Mods:
* Body kit (Cwest Rear, Impul Side, Original OEM front bar)
* 18'' Racing Hart CX - it will come with new tyres before handing over to new owner
* Tein HR
* FMIC
* HKS EVC (Jap 4 / USA 5)
* Blitz Boost Gauge
* Full turbo back exhaust Trust MX with HFC
* HIDs
* Raizen Voltage Stablizer
* K&N filter
* Pioneer stacker
* Clarion screen - plays cds
$20K ono
I also have the following mods which can be included in the car
+ Brand NEW HKS Hipermax II
+ r34 GTR spoiler (with cf insert)
+ Uras Wide Fenders
+ East Bear Plastic GTSR front bar (yes, looks exactly like a GTR vspec including the lip) - plastic quality stuff
+ East Bear genuine CF vented bonnet - the real thing
+ clear front indicators
$24K ono with the extra mods
Looking for sale or trade with:
r34 GT (auto) - cash my way
v35 350gt (coupe) - cash your way
Located in Hills Sydney - make an offer
PM , MSN (k2ii at hotmail dot com) or mobile 0402908338
I have full recipts for fenders and east bear kit inc cf bonnet from powerplay imports, HKS coilovers and various other parts
I also have full japanese original ownership certs, logbooks and user manuals. I have copied english translations too.
Pics below
Fenders and East Bear kit will arrive in 2 weeks or so but this is the kit and bonnet I have ordered from the eastbears website
Edited by ecl
looks good mate, can you send pictures of the front bar and other extras etc to [email protected].
also do you have receipts for the aftermarket parts? mainly the rebuild on the engine.
cheers.
Edited by dr1ft3r
cheers.
will post pics up tomorrow
i will have to dig up the receipt but pretty sure i still have it
the rebuild was done at IS racing located near hurstville with new genuine oem piston, valves and valve seats, tomei headgasket and greddy/trust timing belt
also forgot to mention that the car comes with all genuine nissan manuals, log books, certificates (from japan) and even the name card of the dealer it was bought from =) also have a translation of the manual
stay tune for more pics
Edited by ecl
hey mate, just wondering what did it cost for the bonnet and eastbear kit? pm if need be. im looking at getting one.
cheers luke.
good luck with the sale also.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
