Rx7 Series 4 - Stolen
jonathon
 Share
White Rx7 series 4 Stolen from Elizabeth Bowl - 2pm Tuesday the 21st August.
If you see it call 0438854813.
Chase the f**kers and rip their heads off and deliver them to us, alternativley call the above number, or if all else fails the police (but we know they'll do bugger all).
Cheers
i concur with Darren very nice wankel
my first car was a S1 Rx7 was very nice car stuck to the road like it was on rails always wanted one of those SIV Facelift AKA SV with the round light rearend
The RX7 has been found!!!!!!!!!
Luckily there was bugger all petrol in it, and they didn't make it far (only the next suburb).
As far as I know (being finger printed right as I type), only the ignition is stuffed.
It is my mates car so all credit on the car I must say goes to him.
Cheers boys for your support, and the good news that another car has been recovered.
fkn lucky
hope it has adequete security
oh and lol at MLC & iLEC
lmao
:laughing-smiley-014:
"move it yaself old man !" followed by "pick up the dog turds boyo"
Update - Well the finger printing came back too smuged so no luck there. The car was found in a factory carpark near the edinbourgh defence force, behind gates of the business. Talking to one of the workers - it might have got stolen near shift change, so maybe someone stole it and bloody went to work there. Thankfully it was left over night and the gates were locked so noone could get to it.
Bloody lucky is all I can say.
But here is the lesson to learn - he had no alarm, immobiliser, and the worst part, no insurance. So to all of you out there beware, get yourselves bloody protected!
Wow you would have to be a real idiot to steal a car, drive it to work and then park it in your works carpark lol :cheers:
the world is full of idiots...............sad state of affairs
good to see the car was recovered safely
 Share
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
