2 day i got a pedders safty check n they said my r33 gtst needed a power steering rack n i was jus wonderen if any1 wuld no how much it wuld coast pedders said it wuld coast 700 fitted wuld dat be a gud price or does ne1 no anywhere where i could get it done cheaper n wat r power steering racks worth ur advice wuld be greatly appreciated thanks?
https://www.sau.com.au/forums/topic/181796-power-steering-rack/
phhfffttt i just sold my spare one for $150 but yeh $700 sounds about what pedders would cost for a re-build
thanks mate i appreciate ur help n do u think it wuld be better 2 get it fixed at pedders or go buy a second hand rack n get my mechanic 2 do it which 1 wuld be cheaper thanks?
theres heaps of good second hand ones out there but you'd have to either trust the person your buying it from or know what your looking for when you look at it, not a hard thing for a mechanic to change over an hour 2 tops but thats a stretch
Hi mate, just wondering re pedders telling you that you need a new steering rack. Do you notice anything wrong with your car?
Such as heavy steering compared to other skylines?
my steering feels normal but i need 2 top up d power steering oil every week or so?
They most likely noticed one of the internal seals was leaking. Make sure the rack boots aren't broken and as long as its not pissing out dont bother replacing it just yet. You can get your one rebuilt. That would probably be the cheapest way. Just call around to p/s shops for a price. If you buy 2nd hand its most likely going to fail in the near future too. Not much point in replacing something old with something just as old. If it were me i would rebuild mine if infact its actually necessary. Keep in mind they are suspension people at pedders and will probably try to up-sell it to you.
Deren
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
