They must have changed the design slightly, i fitted one quite a while ago and didnt have the fitting underneath for the auxilliary air valve to plumb in so i didnt use it, managed to just use the idle motor, lucky it ran haltech i guess.
thanks mate from Georgia!! I have bought intake few days ago but firs when i see it i guess that instalation is impossible and there is some mistake ore seller send me other manifold:) again thanks for post and if i will have some problems while instalation i will ask you few advice:)
THANKS THANKS THANKS
re-route the BOV return piping to your new BOV if it's a plumb back. If it's an atmo venting BOV then block the return.
Thanks ...
Please help me
i have installed plenum but have some problem i think i have mistake with pipe connectorsto plenum in nautral rev all times goes up and down i dont know why and i have all time minimal rev 1100 RPM
please can someone help me? it would be grat if you can put the pictures what to connect to the plenum, i thing my problem is in that actually
thanks and waiting for some info:(
Edited by guricha
guys does anyone know what will be consequence if on hight boost this wire will be blocked suddenly??? can it give some detonation ore can damage turbo???
please help me again:)
  • 1 month later...
i started this modification on monday just been spending afternoons working on it, but its nearly finished, just gotta redo the piping and extend the 2 wires for the acv
pics before n after below
i found a few extra steps i had 2 take that werent in the DIY
btw was there a reason why u put ur injectors in upside down? which explains why u had to spin ur fuel reg around?
Yeah, I spun the injectors around so that I could get the wiring harness clipped onto each one easier. If you notice in your pic, they are hard-up against the throttle intake runners. I just wanted to make it look a bit neater really.
yeah mine still clipped on easy enough
i dont like the throttle cable setup though:S wont be long before it snaps i rkn
i still havent plumbed up any of my cooler piping or my acv hose but car drives sweet as
response is unreal lol
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
