  • 3 weeks later...
Not sure if anyone else has had this problem, but worth checking before bolting the manifold on.
In this photo, my output on the water exchanger (oil filter mount) fouled against the socket on the solenoid when trying to slide the manifold on, making it impossible to get the blue plug on once bolted in place.
Had to remove the manifold and give the output a few love taps down to add clearance.
(Mines a genuine GReddy).
Im not sure if this has happend to anyone but once i installed my forward facing plenum my car it begun to miss real bad, runs really rich, missing on idle, back fired really bad going do the road, car is shaking really bad and feels like it wants to die.
Mods I have
3" exhaust
Hks bov
Greddy style plenum
Fuel pump gs043 or whatever
Super spark coilpacks
Air pod
Boost controller (10psi)
Tashiki stage 1 ecu upgrade
Afm,plugs and coilpacks where not touched during the install.
I did Press firm on the tip of one of the injectors but surly can't throw it out this much?
  • Like 1
Just wanted to ask what throttle bodies people are running on these? I'm gonna ditch the adapter and standard throttle body and go for something that will fit nicely and I can get a 3" joiner straight on
Not sure which throttle body to go for. Don't want to spend a fortune on it
I picked up a second-hand Q45 throttle body - it's a direct fit.
Size difference with stock.
Edited by protecon
Yeah I ended up buying one from a member on here :) should be good. Notice much difference compared to stock TB? im not real worried about getting any improvements from it but interested to see if you noticed any difference
Plenum looks good. Im still tossing up o. What colour im going to paint mine
Cheers - build still in progress so haven't been able to fire it up yet.
I had to make up a custom throttle linkage bracket for the side - how did you mount yours?
Any tips on wiring up the Q45 TPS?
  • 3 weeks later...
Bumping this thread back up, have read all the pages so thanks to all those that have contributed.
I will be installing one of these before i get my car tuned on the new computer, for those that have brought one lately, what have you found to be the best copy plenum that is the most complete. i dont want to be chasing down extra parts to get it finished. Also looking for one that has a replacement throttle body and fuel rail something like this, dont really want a chrome one though:
http://www.ebay.com.au/itm/RB25DET-SKYLINE-INLET-INTAKE-MANIFOLD-PLENUM-R32-R33-R34-NISSAN-TURBO-T3-T4-/111159846180?pt=AU_Car_Parts_Accessories&hash=item19e1a4a524&_uhb=1
Thanks in advance
  • 2 months later...
Flicked though most of these pages of this topic,
Has anyone got a guide on fitting to 34gtt?, ive followed the mumbo jumbo instructions in Jap and just a few things missing still, even if someone whos done this
on their GTT can take a few pics of there plenum at front, back, side, underneath????
thanks
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
