this write up is awesome ..! just one thing is i dont remember pulling anything off this metal hose been told its a over flow for the gearbox hmmm i dont think thats right since it travels up to the plenum area .......help would be great..!
  • 3 weeks later...
  • 4 weeks later...
great post :(
but i would not recomend using ebay manifold i got one and when i had everything done i went to put water in and filled no two pot up with water. i relised this by water coming out of my throtle body before i started the car. pulled it of and it was leaking from water gallery to runner. porous cast aluminium. if u are going to do it i would highly recomend pressure testing.
sent it back and they sent me another one LOST POWER and the fuel rail didnt line up....
sanded and polished oem and refitted never happyer
and if you ar going to do this, mount the throtle cable Bracket better than in the picks, or your throttle body will stick open..
so i guess the stock throttle body can fit in these copies as long as i can find adaptor plate
can make your own plate,its not too hard really,:)
'' mines all sealed up no leeks anywhere, but im haveing high idle problems now, even with brown plug off offaac valve,when that is attached it revs even higher. and idle screws one on air control i put right in helps abit. and little one on throtle is screwed outhelps a bit,but still somthing isnt right . with everythng set where it should be it revs at around 1500-2000 can anyone help? cheers.
before fitting one of these you need to make sure everything lines up. i had to chop out a bit of where the AAC valve sits as when i lined it up i found it only had an opening of 1mm, i had to grind it out so it all sat properly - it would have definitely caused an idle problem.
  • 5 months later...
  • 3 weeks later...
  • 3 weeks later...
I don't have a stock 33 one :D
GTR looks like it will fit much better so I ordered one already!
Fingers crossed
Just FYI, don't get a GTR one it's a tad too short :(
Use R33 RB25DET one and cut about 3/4 of a inch off the end!
    • Pete knows these cars well, he does my car too, if he was concerned about the traction arm length for your use he would have said so. Do you have adjustable bushes in that arm, maybe he got enough adjustment there (or maybe the bump steer was not material for your use of the car)
    • Hmm. Yes. I should have been clearer. 1000s for Haltech, for extra headroom. 725s for Nistune. You might even be OK with 640s, but if the possible power ends up much more than 300 rwkW you will run out of headroom on the 640s. That would probably be OK and a signal to not push it to that sort of power with Nistune anyway. At that level you probably do want to be thinking about engine protection functions. Oh, and all of that presumes 98 only, not E85. Well....the 1000s would allow you to run E85 at ~300rwkW territory, again, maybe sort of running out of headroom. Hard to tell with E85 - depends on the tuner as to how rich they like to set it up.
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
