There well supported but a tad basic for street R33(Stinger version) and waste spark etc.You would need the top model to do it right so best to look for a plugin like PFC or Wolf etc. You need Idle speed,VVT,, boost, Aircon request,and closed loop minimum for a nice road car, Stinger uses it outputs for tacho,fuel pump control etc leaving you short on outputs.Ive seen fuel pumps hard wired cause theres no outputs left so if going EMS look for their topend model,and as your saying the price is cheap i think your talking Stinger.The real upside it EMS are fantastic ppl to deal with.
https://www.sau.com.au/forums/topic/181842-ems-ecus/#findComment-3302894
Thanks NIB. I think in the end I may go Wolf, just a shame the dashes are not availble until they find another supplier. IMO PFC's are not really a good choice considering what they are and feature for the prices people are asking, you need to run Z32's with them which is an additional cost and nothings guaranteed because its all 2nd hand now. In comparision (for cost) there are many better choices, the only thing they have going for them is the support for tuning.
Anyway my intake/turbo setup is..
HKS GT2530
SARD BOV
3" Turbo back exhaust (inc stainless steel dump/front)
Hi flo cat
Pod
With an ECU i suppose i should get around 300rwhp?
https://www.sau.com.au/forums/topic/181842-ems-ecus/#findComment-3304298
will be putting one of these in my 32 very soon spoke to a mechanic who tunes these all day everyday he was telling me he tuned a 32 rb20 only mods he had was pod filter after market intercooler and 3'' cat back exhaust and the thing pulled 197rwks on 10psi will let yas know what mine pulls out when i get it done
https://www.sau.com.au/forums/topic/181842-ems-ecus/#findComment-3305246
I find that very hard to believe.. must have been a very generous dyno..
https://www.sau.com.au/forums/topic/181842-ems-ecus/#findComment-3305471
Will need a good Turbo for that.
https://www.sau.com.au/forums/topic/181842-ems-ecus/#findComment-3305930
stinger is a great little ecu for a basic setup converting a car on a carby to an efi setup.
For a nissan it's not a good move.
how come??
my car has made over 400 hp@ 27psi on NIB's dyno with the stinger. stock internaled rb20...
my best mate converted a series2 rb25 into his r32 with gt30 and stinger and that made close on 400 aswell
there an awesome bang for buck ecu, u dont need to wire it up as a standalone it can be pickybacked aswell meaning you keep a few outputs.
they have just realesed a whole new range aswell which would be worth looking into
https://www.sau.com.au/forums/topic/181842-ems-ecus/#findComment-3306052
how come??
I like the stinger myself , I had one not long ago running a turbo efi converted A14 in a datsun 1200 ute.
Power numbers themselves aren't a measure of how good an ecu is, the setup is a complete pain in the ass compared to things on the market that have plug in abillity to suit the RB nissans. But If you like mucking around then why not?
hows the fuel ecconomy on yours?
https://www.sau.com.au/forums/topic/181842-ems-ecus/#findComment-3306293
yeah true i can understand the wiring up as being an issue to some, but it made life a hell of alot easier to me (managed to ditch most of it from the exhaust side)
agreed on the power thing but 27psi on the internal map sensor... no need to upgrade to bigger sensor unlike some of the more expensive ecu's on the market.
fuel ecconomy is like any hard tuned car,I see 350km to a tank with light driving and with full throttle hill runs type driving (on off on off) ive seen up to 400 a tank :rolleyes:
https://www.sau.com.au/forums/topic/181842-ems-ecus/#findComment-3306403
You must be kidding. Is that even possible with such mods? I find it hard to believe man. As bubba said, must be a very generous dyno.
https://www.sau.com.au/forums/topic/181842-ems-ecus/#findComment-3306618
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
