Cruise Alice
Sklyn
 Share
Since the next meet is April 20th. Could you do us all a favor. Since you've been in it now and pay'd for it. Could you place the prices down for us boys. We're all hearing diffrent prices and you've been in it.
So price for Superstreet class? $149 ANDRA year
Price for Street class? $80 ANDRA year
And do we have to get a ANDRA licence? Yes but a $20 day licence is fine
Like wise for the CADRA Licence? Yes it covers insurance, track hire, power & water, parking in pits for your car & pit crew etc
Ah.. How much does it then cost for each meeting? $75 Street & $125 Super Street (includes free entry for 3 pit crew)
What do you need to race? Helmet, overalls or long sleeves & pants, shoes, 1/2 tank of fuel, shade, seat & water (for waiting around)
Whats the go with the $25 membership? is optional but supports the club & only members are eligible for trophys or championship points
Anything else i've missed please put it in. Sorry about the Questions but it be good to hear it from you since you've competed.
These prices are comparable to other tracks I have visited around the country. I have found it is alot more fun being in the pits with your mates(pit crew) than being a spectator. There always was something to see or do and you also get to see behind the scenes during the event. We had 2 3x3metre shade tents we brought for the cars and crew which made things very comfortable. We had 8-10 mates in our area with 3-4 support cars and had visits from family & friends during the day. They all thought it was great.
:ninja:
Guest Rexlr8
$125 per meeting is abit out there in price...
I dont mind paying $149 for the YEAR but not $125 per damn meeting. Anyone thought we racing for cattle stations lol.
Guest Rexlr8
Yeah i know its in a saftey environment and all that jazz but still.. Is a bit steep tho. Specially when the track aint even complete or anything as they were saying before. But i guess better then racing a dodgey blathaskite run :D
If a meet is on a saturday and sunday, does that $125 cover both days? Or for street class the $75.
I would have spent $75-125 on piss some nights, so it doesnt seem that bad to me for 2 days racing.
If you bought 4 pit passes as spectators it would cost 4 x $15 for entry, while you get these included in the drivers $75-125 entry fee.
I got approx 15 1/4 passes over the weekend, but I would think there would be more next time with less competiton cars there.
Go the T51R!
Guest Rexlr8
You hook a cruise up and im sure plenty will arrive from all directions. Nothing else to do in this tumble weed town, might aswell cruise with mates and their cars.
Guest Rexlr8
My oil cooler arrived finally! Went to go look at prices for oil.. Man, Motul 300V is 100$ per 4lts :thanks: I now take 5.5tlrs...
I'll just use Motul Turbo light. Only $57 per 5lts.. Kittles charge $150 flat, i rekon using good oils and parts i can still come out with change.
But... oil cooler aint going on for another 3000k's. I dont want to buy oil now, use 3,000k's and then buy more again. Or should i?... Next service is due in 3000ks. The i can finally hook my gauges up aswell.
My excitment for the day in this town..
If your organising a cruise, do it soon as its getting colder by the day :D
 Share
    • There's probably an underlying issue with the A/C system too. I recently fixed mine, now it's fully control by the Haltech and car's factory HVAC controller  Have a squiz here:
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
    • Deeve, I don't suppose that you've made any progress on this? My Stagea has the exact same problem, and just like you, I've read through as much as I can online, with no real progress. My car isn't throwing any codes at all, which is a little frustrating. I've changed plugs, checked the wiring and harness. A new MAF gets here next week, but I'm not hopeful it will solve the issue.
