Cruise Alice
Sklyn
 Share
I don't really like the new GTR!! I'd much prefer your's Ben, or a 34 GTR..just don't really like how it looks!
Don't get me wrong though. It is an awsome car and would be more than happy for it to live in my driveway!
Beach Volleyball--I'm in!
So, wednesday night at Elder st...is that right? what time? 6 or 7 I rekon it used to be (years ago) where on Elder st?
You missed out last night Fab! cruised everywhere..
haha, we were kickin around a foam ball, hacky sack style and this dude went ass up and as he landed head first his drink hit the ground and blew up straight in his face!!!! should have seen it man, funniest thing I've seen in ages.
hey, any of you guys cruise out to mt isa, quite a few skylines around here, i got a r33 impul pretty much stock atm apart from the exhaust and pod filter, got fmic and boost control on the way tho, if any of yas are ever out this way give us a yell. cheers dan
pass lol ill think about it if u will shout the fuel and running costs lol oi i read in the paper today al stainer the boss of the dragstrip. is complaining about hoons saying we need to grow up and get a life and to come out to drags and do it in a safe environment, and that paying the membership fees etc are cheaper than paying the fine. wich is all well and true but i reckon we should write a response to all the stuff being written about us giving us a bad name
Guest Rexlr8
Maybe if they wernt charging like a wounded bull for the strip things might change. As for hooning... Fri and sat nights... If we are lucky to leave the friggan car wash. Lee man, im with you on the respons. f**king over this shit im readin in the paper. Its funny, they'll send 3 f**king paddies to us at blathaskite or somewhere but when real things happen in town. Eg: young kids waiting at melankas, or walking the damn street causing trouble., they dont do shit... f**k ass town.
Sure drag strip is best thing since sliced bread for this town, but once a month do they really think they'll keep us of the street.
They point you boys out in the skyline. What about jess in that lancer, or all the other P-platers and shit. We have done up cars so its instantly our fault..
yeah, tis a bit far but a few guys are talking of going up to Darwin so you never know.
Last time I went through Isa i was wondering if the roads were made from tyre rubber there was so many burnouts!! lol :whistling:
Same goes Dan, if your in Alice. Catch up for a cruise..
 Share
    • There's probably an underlying issue with the A/C system too. I recently fixed mine, now it's fully control by the Haltech and car's factory HVAC controller  Have a squiz here:
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
    • Deeve, I don't suppose that you've made any progress on this? My Stagea has the exact same problem, and just like you, I've read through as much as I can online, with no real progress. My car isn't throwing any codes at all, which is a little frustrating. I've changed plugs, checked the wiring and harness. A new MAF gets here next week, but I'm not hopeful it will solve the issue.
