Cruise Alice
Sklyn
 Share
In the words of the black knight "can't we all just get along" ha ha.
hey man no peer pressure here like i said its your call, best plan, save some money, do your coil packs and get it tuned when you have the money, jsut means youll have to live with it a bit longer and baby it.
moving on
whats happening tonight? anybody appart from pinksta (welcome back) going to be out tonight?? im still waiting on parts :) so no hard driving for me, just put around...
Guest Rexlr8
I'll be defently at the drag strip!
I changed my G-box oil the other night. Thanks to ryan mind you.
I had bad crunching from 3rd to 4th. Anything after 3,500rpm it crunched. And likewise from 4th to 5th.
That was geniune ( Cant spell for shit ) subaru gbox oil in there with nulon addative. Worked for a bit. Survived a day on the dyno.
But it just grew worse. I brought some Redline Gearbox oil. Type: Lightweight shockproof. Aka, smurfs blood. Normally around $220 delivered for 3.8lts i got mine for $111.50 for 3.8ltrs.
www.performancelub.com Check it out peoples. Great oils and fast Delivery. 3 working days to NT to my door.
Anyway. I put it in, as soon as everything was warmed up. Flogging time!!! Every gear much more direct with no sign of crunching through 1st to 3rd... Now... test time... Gave it hell to top of 3rd and changed.... Guess what. No damn crunch! I'll be happy to prove it too people too! You could hear the crunch with original oil over my sterio... No shit. The oil has a much more direct feel to it and alot smoother! Bad thing is.. Theres alot of downsides. You have to make sure you can get every last drop of your old oil out. I let mine sit for the whole night and most of the day. She was empty! Other wise it mixes and turns to Jelly... No good. And... you cant go from redline back to another brand without flushing your box many times with cheap cheap oil. It mixes with the new oil and makes it bad. And can actually fail and destroy your box. But defently something for you boys to look at. Also... It says on the bottle 500,000k life span... If you drive a damn golf buggy. For most wrxs it's between 10-15ks max.. But thats awd and hard launching. All your boxes are stronger then mine so the effect's will be greater with the oil i'd imagine. And life span alot better. Check the threads here about REDLINE. Some hate it, some love it. Im a lover :P
Harold at that website is awsome. He just rose his price's tho. Only by 5-10$ tho. Im really happy about it.
Anyway. Enough Late night tele marketing. Now remember, if you buy 1, you get 1 absolutly free. And if you use your credit card. I'll throw a smack in the head free for not doing it sooner!
Good luck at the dyno
Guest Rexlr8
And cammo, $111.50 aint expensive for 3.8ltrs of life saving oil :) Its alot better then the last quote ive got which was $220 inc delivery.
hey guys, good turnout at the drags lucky no big problems today.
im putting some of the videos from the day up on u tube if people want to check them out, i also have the movies from the dyno night if anyone want them i got them on disk.
 Share
    • There is a LOT of stuff that can be done, it all depends on how much time and money you want to spend on doing in.  Not all ECUs will be able to do it, and the more control you need the more time and knowledge needs to be put into making it work.  If you're willing to spend the time and money and have the right hardware and skills involved there's a lot that can be done.
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
