Cruise Alice
Sklyn
 Share
count me in for now, there is always a possibility I have to work..
Did you ring Ross River? last time I went out they were very rude and basically kicked us out because we brought a can of coke and a pack of chips.
Very rudely told us we couldn't bring anything on their property, and offered NO hospitality at all.
Last I heard locals could not use the pool or BBQ area. I hope there are new people out there..................
Its about 100 k's each way i think.. and a small section on dirt! like 200m.
Yeah ryan, do what you said you were going to do the other night.
a nice zorst, intake, and the restricting parts for better flow. Worry about the diff later when your pushing some bigger numbers.
But before that, get the bastard here!!
its getting closer haha only 11 days to go..... god the days are taking longer and longer man i tell ya haha.....
oi the 16th is a sunday i ment the 15th and were gion to ross river there all ready 6 cars goin on this cruz we need more
yeah count me in for jims place or ross river. i dont care... let you know if i cant make it for some reason.
yeah fully... you havent had a lot of luck so far hey. but at least you know when it is finally back on the road you wont have any problems with the engine. do it right the first time :ermm:......... sadly just takes longer
hey fellas whats happening? deons workin on my car tonight he quoted me 8 hours 4 the timing belt if everything goes smooth 500 bucks , but if he has to tap into the crank pulley then no more than $700 , should take him couple days so i should be out this weekend if it all goes good , so all in all looking at around $800-$1000 for timing belt kit and labour , its a pain in the ass but it has to be done id rather do that then replace a whole new engine , altho theyre going for only like 1500 these days..... project car anyone???? lol im thinking tiny old budju car with fullysic rb25det?? lol one can only dream
Hey guys long time no speak!!!! i have placed the same vid of fab out show groungs on u youtube so yea ill post the link up next time im on unless someone finds it and does it first, im up for the cruise to if the pulsar makes it through the dargs in nov, catchas next time
ooo guess what i saw today the brand new camaro ( the one from transformers) i.e bumblebee , i ran over 2 the truck and snapped some pics of the interior and engine bay , ill post em up tomoro it looks sic as keep ya eye out there's 2 of them both black and white triangles all over it.
Hi all finally got the r32 skyline on the road (only took 12 months) still needs tuning should be doing that on
the weekend hope to make the drags and the cruise if all goes well
hey yea i have seen that driving around, 12 months hey sounds like my car, how is chris goin with it???
Lee, post pics here!!
http://www.skylinesaustralia.com/forums/Sp...24#entry4174324
Spotted in Alice thread...
Good to know the Test cars are still coming to town even with the speed limits.....
You should put RB in the Pulsar.....
Your car will be more than meetsthe eye soon... blow me away finally maybe??? lol
Good stuff Pete, hope to see you around soon!
 Share
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
