Cruise Alice
Sklyn
 Share
That'll be cool. I'm all booked to fly out this saturday to pick up the new daily driver that will only see weekends. Might have another car sorted too, in the V8 variety though. Perfect rig to put fmlywgn on the plates :P
Hey guys sold the exa to chris so wen i get the money i can pay off my loan and go get my new car hoping to be by the end of the month let im excited u will know wen it gets to town
Hey guys, jordan was sayin the orther nigh that there might be cruise on this weekend???
if notanyone intersested in the weekend after drags, a cruise out to standley chasm, or if anyone has any other good places maybe somewere up north???? post up ya replies
So where then?? make a suggestion.
What about Standley Chasm?? Not sure if they have BBQ set up though..
I rekon Dallas is still here though not seen him, just various cars at Street Torque and open shed, so someone is there.
Drag strip should be good. Hope it has coldish weather tho. 2:00 starts is in the middle of the heatwave lol. Excited about the car kurt? Should be good as. And hope it dont fail on you on the way backhere. That'll suck ass.
Good stuff Andrew, hope the scoop works :banana: and see what times the lil pulsa pushes!
Who is actually RUNNING in the drag? and is it test and tune runs or something else?
Yeah i'll be getting the rexy out there for last runs of the year. I want to see what the black wrx runs with just a cat back zorst.
Craig, drags will be grudge matches. No set bracket or anything like that. Just like a test and tune.
Fly out tommorow, be back tuesday night.
I can give ya a hand one night next week on that suspension jimmy, your just putting coils overs in yeah? My number is 0419856391. Let me know anyway.
 Share
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
