Cruise Alice
Sklyn
 Share
Yeah, Get Dr Drift to give him a call and he can work out a trade rate for Dyno use and then you just pay the Doc and he will pay Dallas.
otherwise you'll have to pay full price for dyno run plus pay Dr for his services..
Dallas is happy for him to use his Dyno, so no prob there.
Street Torque Ph is (08) 89 52 7755
hey guys good to hear you's all ran good times, congratz kurt on your time and bk i heard you were flying over the weekend, thats wicked as man, any plans coming up for the car other than a cage now you've hit the 10's??
2 x Bosch 044 fuel pumps, 1000cc sard injectors, swirl tank, another oS giken triple plate clutch, HKS twin power CDI unit, power fc d-jetro (instead of my fc pro), new 7 point cage and maybe different coilovers. Will be tuned while I'm at the Big day out to 2 bar on 98 ultimate and 109 Sunoco. Have to keep the fastest street car times away from that bloody Mustang.
wats up fellas the dude that i was gona buy the motor off sold it on me but i found another 1 with nismo turbos on it and shit so im gona grab it off him next week cant wait
Ah that sucks man.
Least you have a new engine coming then. Nismo turbo's, what else she got?
meatal head gasket and cams low ks on it but it will hav
700cc injectors
apexi pod filters
apexi power fc d-jetro
clear timing belt cover
trust fuel rail
hope not just need to find a y peace for the intercooler so it goes 2 into one havent been able to find any yet but every thing bolts up and getting it tuned and wired up in adelaid by boost workx melo knows them very well they reackon $800-1300 to wire the who car up and tune for 300 to 330 rwkw
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
