Cruise Alice
Sklyn
 Share
wat u talkin bout its fully hectic now lol
oh and for you guys who dont know yet i am leaving town on the 28th of feb heading down to mount gambier with family get outa this town down to the cold weather which will suck
Edited by JstPlyn
wats up parts arrived 2day motor should be here 2morrow old engine is almost out just hav to undo exzaust so it will be out friday night and other 1 in buy next week sumtime
hey guys funny story i dropped my keys last night and when i put the transponder for the alarm back together the alarm wouldnt disarm and the alarm kept going off , so i disconnected the battery and it stopped , so today i cut the wirs and went to start the car and funnily enough my car has an imobiliser lol woops. so i re soldered the wires and magically the car started the alarm disarmed and the car is now working perfectly , so i threw away the remote so this never happens again hmmmmm weird lets just hope the alarm or immobiliser dont decide that one day theyre not happy and wanna go off.
yea me and melo r all goin speedway 2 night so should see u all there motor dident arrive so hopyfully monday can wait probly hav it back 1st or 2nd week of january low boost at 250rwkw and hi at 320rwkw my clutch only good 4 330rwkw
wats up got the motor out last night but ran into a problem both my engine mount r completely f**ked they wernt even joined to the motorthe only thing holding them in was the nuts under the car but ordered sum nismo 1ns and a fuel pump so should be here thursday and if the motor rocks up 2 morrow should hav it in buy the weekend
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
