Cruise Alice
Sklyn
 Share
Oscar, how the hell did you manage the 11.7 in RWD ?
Easy exactly same procedure as AWD. Long smoky burnout, launch on limiter and hang on.
I was still getting wheelspin on the 3-4th change at over 100mph :) I'm sure if I practised more I would get low 11's
I heard something about another accident that only just missed a small pole
Another street drifters close encounter with a gutter. Heard it was suspension damage only.
Any more details yet Cameron?
I'm all set for the drags again tomorrow. :D
Anyone needing S13 parts should come & see me or pm me if you don't know me. I am still stripping Ryan's old '92 Silvia shell and there is not much left.
Best bits available would be the front seats, all glass, rear subframe complete, minor interior parts and shell rear of the A pillars.
What ever is left in a few weeks time will be going to the wreckers or crusher. All cheap especially if you want to take the bits off yourself.
Dunno if you guys know yet but its $100 to enter the 1320 event. i wonder why the price hike?
What do you mean ? Dudes are coming from the US and you think it's gonna be like an off street meet ? Bracket racing in super street is about as expensive as that normally if you don't have a s/st ANDRA license, and even more expensive in super sedan ($125 + license). And it's $80 if you nominate now, $100 on day. It will be extra to have a one day license too.
I'm wondering how strict the scruteneering will be. If they are relaxed about it that will really piss me off as the only reason I'm not racing is because of ANDRA rules. Both cars are ready to rock mechanically but R32 still needs battery isolator, fit new 5 point seat/rail, 5 point harness, side intrusion bar on cage, tailshaft loop, new race gear, $9 a litre unleaded, upgrade to group 3 unlimited ANDRA license, parachute yada yada yada. It just goes on and on. I just need to get the R32 back out there to see where I'm at. You guys have no idea the money that's been poured into my GTRs. (could've had an R35 already put it that way) :)
Good news for this event is tail shaft loop is only required in the 10 sec zone (ANDRA says 11) but harnesses will be enforced in the 11 sec zone OR 110 mph. I've tried telling everyone - don't say you were not warned.
I spoke to Andrew Cole today over the phone and scrutineering won't be any different to any other meet. So whatever you normally do to prepare your ca for racing is what will be required on the day. Hope to see you out there Ben.
Oh yeah !!!! I'll be out there now in the V spec defintely. Lets just say it's time to show what the white car is really all about.
Should be very interesting MR. MFP !
the weekend was good with lots of good races, carmelo was running strong all day after the snapped axle.
i had my car on the dyno the other day to see how the afr are so here is the dyno sheet....... its running at 10:2 AFR so it really rich but should be getting that sorted when dr.drift comes up.
i am pulling this turbo off soon to send back and be updated to a more responsive turbo
 Share
    • Its likely to be 70% road 30% track usage, track usage will increase if anything. Decided not to fit it as I cant be arsed changing the bushes on my LCAs again 🤣 I did get the below back from GKTech though so they should work together     The anti-squat kit and roll center adjusters work independently since they change the rear lower control arm's angle in different ways. The anti-squat kit adjusts the angle from front to back, which impacts anti-squat values. Roll center adjusters change the angle side to side, mainly to correct geometry on cars that are significantly lowered. They might affect each other a tiny bit, but overall, you can think of them as separate.
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
    • I find I am using the MX5 for everything except long overnight cruises with Jackie, or, if picking up the kids to go somewhere, the SS has so much more room inside, and is much more comfortable if your going to be doing Hwy driving for 6-8 hours And the MX5 isn't bad in stop go traffic for a manual transmission car, whilst the clutch kit has been upgraded from stock, it is still light, and also not having a stupidly light flywheel in it helps as well, I've spent alot of time sitting on the M5, M4 and M7 stuck in traffic when plodding around the Greater Sydney Region in it Another benefit is MX5's are not really a car that gets stolen, you can pretty much park it anywhere, and it will still be there when you return
    • I can totally get why you like it for that sort of commute. I was thinking BoganDore because it's such a lazy drive, for things like stop start traffic.   I used to do over an hour in stop start shit from one side of Bris to the next, twice a day. My choice of car was larger displacement, with an auto. Basically for torque in low rpm/very low speed, and no clutch pedal. But loved a fun manual for the weekends, which the partner has (plus had the LandCruiser too for other fun drives). I now have an EV as a work car, and I tell ya what, ultimate daily driver, especially if youre out of energy, like I often am after work. I don't even need to touch the brake pedal   That said, I'm presently rebuilding the Liberty GTB to get it setup for weekend drives and track abuse! So small high revving turbo engine with 6 speed cog swapper!   But for your style of commute, I'd probably take the MX5 too!   For those choices, I'm ignoring fuel economy. Because I know how atrocious V8 daily life is for fuel from when I used to daily a manual SS, ha ha. Hence why I know I love the daily rumble of a V8
    • II know what u are saying after 9 years of hibernating my stock engined  110,00km gtt I got it registered 2 weeks ago. Took it for a drive a couple of days ago and some fresh bp fuel, I just couldn’t stop grinning and dreaming of when I will start my build thread. its just such a primal man feeling many forget to enjoy I wish u so much enjoyment with your little racer mate
