Cruise Alice
Sklyn
 Share
oh nice well here in mount gambier we have commodore after commodore after commodore its stupid, two mate got there cars inpounded today a onevia and s15 for a small slide lol
yesterday we went out into the pines and sliding on dirt road it so fun
its only half hour drive to the beach, and other decent towns, some wicked roads around the lake, the night life is SHIT they dont evan hav a casino and there arent many imports
Pretty quiet in here, has every ones cars died ? The blue R32 is still a few weeks off dammit! The new bottom end build has turned into complete new long motor build including nitto oil pump, trust sump, $1700 tomei valve springs, new valves, custom head oil drain setup and T51 turbo rebuild. Just the cams will be left from the old engine. What a head fcuk !
32GTR has been in the shed since the last bracket race. Like most gt-r owners I am spending more time and money working on it than driving it.
Also buying 2 more commodores has distracted me again and getting ready for speedway season.
Few things to sort out but I will be racing saturday. So far have fitted HKS oil cooler & DLI, Koyo radiator & silicon hoses, Kics r40 open nuts, Cusco plate relocate and Nissan oem radiator rubbers, gearbox boot & bush, coilpack loom, exhaust bracket etc. Have already removed my a/c foward of the firewall and plenty more is going to get pulled. Still got rego & other bits to fit but running out of time. I will just be out for burnouts and fun on sat.
Next year I will be buying more M/T's, stripping more weight and then probably cage time. Hopefully 10's on a budget or bust!!!
GTR and budget in the same sentence, good on ya ozzie. Then what - 10.9s or so, what then you'll need to jump in the deep end like me to go significantly faster and reliably. Your stock bottom end ain't gonna last forever, (or your box). What times it on tommorrow ? I might think about trying to get the R33 down 11.5 or better. Give me a ring tomorrow gaylord, I'm going to the cas now to try and win some R32 funds !
You know I only enjoy taking your sweet arse on the track honey :(
I will be doing my usual last minute slap together, got to buy a smaller battery because of the oil cooler. Probably head down around 1-2, racing starts at 3. Burnouts and 11.4 again or quicker on my 'budget' chinese tyres.
was a good meeting overall i think, finally got to get my car out for a meeting. ran a best of 13.099 which is pretty good i think since its only running a mailtune and only on wastegate pressure.
I didnt have any major problems out there except on the way back into town when my gearbox started to whine. will be looking for a replacement now. i didnt think it was going to hang on for long seeing as it was already crunching second and third before i went out lol
Meeting worked out well. Had the normal couple of glitches to start but things happened after the sun was going down. I ran a new PB of 12.05 @ 122mph still on regular street tyres. Congrats to Cam for the times he was firing out. Carmelo did a good job shaving a second off the mazda's times. Ryan with the capella blew his gearbox, and Benny got himself some time slips too.
so u got all your stuff on your car now kirt?
my car is up for sale now if anyone up there is interested ill come to alice to drop it off as well at buyers expense
 Share
    • Its likely to be 70% road 30% track usage, track usage will increase if anything. Decided not to fit it as I cant be arsed changing the bushes on my LCAs again 🤣 I did get the below back from GKTech though so they should work together     The anti-squat kit and roll center adjusters work independently since they change the rear lower control arm's angle in different ways. The anti-squat kit adjusts the angle from front to back, which impacts anti-squat values. Roll center adjusters change the angle side to side, mainly to correct geometry on cars that are significantly lowered. They might affect each other a tiny bit, but overall, you can think of them as separate.
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
    • I find I am using the MX5 for everything except long overnight cruises with Jackie, or, if picking up the kids to go somewhere, the SS has so much more room inside, and is much more comfortable if your going to be doing Hwy driving for 6-8 hours And the MX5 isn't bad in stop go traffic for a manual transmission car, whilst the clutch kit has been upgraded from stock, it is still light, and also not having a stupidly light flywheel in it helps as well, I've spent alot of time sitting on the M5, M4 and M7 stuck in traffic when plodding around the Greater Sydney Region in it Another benefit is MX5's are not really a car that gets stolen, you can pretty much park it anywhere, and it will still be there when you return
    • I can totally get why you like it for that sort of commute. I was thinking BoganDore because it's such a lazy drive, for things like stop start traffic.   I used to do over an hour in stop start shit from one side of Bris to the next, twice a day. My choice of car was larger displacement, with an auto. Basically for torque in low rpm/very low speed, and no clutch pedal. But loved a fun manual for the weekends, which the partner has (plus had the LandCruiser too for other fun drives). I now have an EV as a work car, and I tell ya what, ultimate daily driver, especially if youre out of energy, like I often am after work. I don't even need to touch the brake pedal   That said, I'm presently rebuilding the Liberty GTB to get it setup for weekend drives and track abuse! So small high revving turbo engine with 6 speed cog swapper!   But for your style of commute, I'd probably take the MX5 too!   For those choices, I'm ignoring fuel economy. Because I know how atrocious V8 daily life is for fuel from when I used to daily a manual SS, ha ha. Hence why I know I love the daily rumble of a V8
    • II know what u are saying after 9 years of hibernating my stock engined  110,00km gtt I got it registered 2 weeks ago. Took it for a drive a couple of days ago and some fresh bp fuel, I just couldn’t stop grinning and dreaming of when I will start my build thread. its just such a primal man feeling many forget to enjoy I wish u so much enjoyment with your little racer mate
