thanks kurt, going to pull my rear wheels off first and see if i can find the reason why i have positive camber on one wheel. if its a bent arm ill replace it then maybe space my other wheel out so it sits the same on both side and learn to drift in it. If i cant find why its like that then ill be purchasing something to put my engine into
  • 3 weeks later...
lol well quick update on my car DEFECTED
yep i went to adelaide on fri and got defectet so now have to change steering wheel, romove turbo timer, remove avcr, remove bov, change suspention back to stock and remove strut braces and put on stock exhaust
I HATE SA :)
Lol cammo. And people cry about the Territory. We're pretty casual here. Cops only bother you if you draw attention to yourself.
Had a bit of a run with a so called 300rwkw FG XR6 Turbo. My car appears to pull harder in every gear, even gave him a head start and caught him before the gear change and with mountains of wheel spin.
Edited by fmlycar
This wouldnn't happen to be " Panos " or how ever you spell it? I also gave him a run but this was before his apparent tune-up that Ryan ( 6sin ) told me.
I was talking with my boss yesturday, he's pretty keen to try and source Caltex 98 and sell it. He's still in talking stages now but was curious if you boys would use it over BP 98?
Price is a hard stone to step, he is trying to sell it only 2-3cents cheaper then BP, but even if he has to sell it same price, we do offer the 8cent vouchers on ALL fuel?
So pretty much who is keen to use it?
I could be interested in a new blend! Would be great if we could get 100 or E85 at the pump, but that probably is as likely as us getting a drift track
/wiki/File:Gojira_1954_Japanese_poster.jpggojira_1954_poster.review.jpg It lives!!! Spotted in northside looking for a battle or maybe smaller prey to crush, mmm bumperless 180's
Good to see you out enjoying your GT-R on the streets again!!! Might catch up over the weekend, or call past my wrecking yard. I will be there as usual working on high tech 100kw aussie monsters
I'll be keen to give caltex brew a go.
Burnout comp is coming and I've picked up a sponsor so I may as well make an effort and see what kind of skid my car can do. Anyone who has 15 inch 4x114.3 rims they can lend would be appreciated. Just give me a call 0419 856 391
I think Lee said Ozzy had some. I'll get in touch some time this week.
well dont know how many know but car got defected in adelaide few weekends back for bov, turbo timer and boost controller
so i removed bov, hid the turbo timer and boost controller (cbf taking them out) put on standard suspention, exhaust and removed strut braces.
Took the car for inspection now i need
-Normal headlight globes
-Normal parker globes
-Standard turbo and induction
-There are stress cracks in the wheel wells which need welding and a metal plate to strengthen the area
-Fix exhaust leak
martin was lucky because he was right in front of me and the cop didnt evan look at him
I HATE SA RULES
Were you driving like a dick or just random pick you up? I hope i don't get the same fate as what you did when i get there in 2 months.
Caltex 98 fuel is a no go. The suppliers in Adelaide can't get it to us, as they recieve there source from Melbourne. By the time it reaches us, the price would be through the roof. Sorry guys, boss tried hard to get it for us.
yeah, he was out to get you, after we left he packed up and left... I got my car tuned at Jazmac the other day and as some of you might know it made 297KW in Alice, turns out this figure was actually 207KW, i wonder how that happened... I'm not looking forward to getting my first defect, i think ill have to visit NT to get it taken off...
Craig when youre in Adel' hit me up, im living down here now
    • Saruthewhite hasn’t been on our site since November 2016 sorry mate
    • Note when Duncan says that, he means "when you're not using the correct lifting points on the sills, because you want to work on the sills. A 2 post hoist is not appropriate for everything anyway, and working on the sills is a good example of that, because the arms go under ths sills anyway. You're better off finding another way to support the car off the ground. Beyond that everything else D said is correct. Only the dedicated jacking points are the correct place to lift. Anywhere else is incorrect, extra caution and awareness must be used, etc etc.
    • Your off site links didn't work for me, and in any case it is easier for forum members if you post the pic directly either as an attachment or a link so the information is all in one place. That aside, the sills are the correct place to lift the car, whether with the factory jack or a hoist. Yes you should use rubber blocks with a slit for the seam on a hoist to avoid bending the pinch weld (where yours is currently bent, just bend it back if possible eg vicegrips), and be aware of the height you need in the blocks to clear any sill extensions to the hoist arms as it lifts If what you are doing needs access to the sills, the rear subframe bush would also be strong and secure. I'm not sure what you mean by sidemember (maybe same part I mean by sills) but be careful that your front support point is not too far back as the car is very front heavy and could overbalance.
    • Here's my first iteration - white duct tape so color is off, but this is just a straight line across the bonnet lip. From a geometry standpoint, this is probably closest to what a GTR has. Next up is some $5 white pearl vinyl and some rubber door sill trim, applied to the BACK of the bonnet lip. It's more accurate placement to the GTR, but also follows the body lines on this setup a bit more. Couple more pics on this config incoming: Again, a $5 vinyl and rubber job, it's  POC still and not how I'm gonna run this part. But one thing I'll note is that the black trim does need to "straighten out" a bit, and instead of going completely along the line of the bonnet lip, might be better suited to wrap over the "horns" of the bonnet lip, giving it a less aggressive curve up at the ends.  The correct way to do this would be to paint it body-matched and then decide how you want to make the black line. If you used paint or a pinstripe, you could have the black line go straight to the corner of the headlight where the rubber strip typically meets the headlight on a GTR.   Hope this helps!
