Trying to find the time to run my car in. Still done less than 400km. D'oh!
Regarding Adelaide tuners from above posts- Turbo tune are a bit *** from personal experience (wouldn't go again) and Morpowa and Tilbrook use Martin Donnon from Willall Racing to tune their cars. In fact, nearly everyone tuning anything remotely serious in Adelaide sub contracts Donnon to do their tuning - V8 or import. He really is a cut above everyone else in SA.
Nice guys, im missing out! BK, have you used Martin in the past? I'm keen for a re-re-tune, im a paranoid *... What do you guys know about Yokohama Advan Sport tyres? i just got a set, cost $435 a piece and was wondering if I got ripped off or if theyre worth it? As for mods, ima do my fuel pump (paranoia) then look at the option of either forging an RB30 or RB25, or selling and buying a better platform... Or buy a house
Edited by Childzy
Hi mate. Yeah I've used Martin. He does know his shit but IF you want your off boost sorted for fuel economy you gotta make that pretty clear to him, as he didn't want to do it on my 32 (read : Very lazy). Still he's probably the #1 pick in SA, just gotta get him to tune EXACTLY what you want.
The Yoko ADVAN sport v103 are you talking about ? I run them on my R33GTR and retailed for $790 each as 275/35/R18 when Sambo was running Tyrepower. He gave them to me for $650 each so yes they are expensive, but they're Y rated tyres for going 300km/h +
Oh I forgot to add, Martin at Willall is expensive for tuning.
Edited by BK
my 2 cents, BUY A HOUSE!!!
Keep car mods to minimum then step up to a better platform in a few years. R34/5 will only get cheaper.
+1 for tunes from Martin, you only get what you pay for. He helped with r&d and parts to get the first r35 into the nines.
Experience like his from exotics to v8s will never come cheap.
Dammit man. What are you converting it to?
I like the sound of being #1 in SA, might get that done before I go to Canberra then. Those Yoko's are awesome, barely any wheel spin now and they ride beautifully.
How expensive are we talking? I know you can't give an exact number, I'm just after an idea like if it's going to be thousands or under $1k.
Cheers
Two posts in a row, I feel like a post whore...
Does anyone have any INDEPENDENT oil test results from various engine oils?
Im wanting some actual proof that the oil im going to buy is the best for my car and not just the best advertised.
I found I review from American streetcommodores.com (http://www.animegame.com/cars/Oil%20Tests.pdf) which has some good stuff in it and has a couple international brands we get here but im really after a test on domestic oils we would be likely to find in our stores. There also seems to be alot of controversy over oil and air filters too that would be nice to have sorted out. Can anyone help? I really want to be putting the best through my lovely lady (skyline)
Cheers, marty
Guest Rexlr8
Thats the exact same PDF i have saved on my computer from like 2 years ago.
Only thing i have found to be any use for information ever since dude. I think these days alot of keyboard warriors just say use this, use that. Blah blah. Go with what you think will be good for the $$.
I'm using ULX-110 engine oil, 10w40.
Air filter results:
http://www.australianauto.com.au/HTM...hoot%20Out.pdf
Edited by Rexlr8
Street commodores did a dry bearing test a few years back. Penrite Sin series of oils were the best. I have used that and royal purple and seems to be much of a muchness between them. Just avoid the stuff like mobil1, fuchs and a couple other brands that I can't remember right now. They are about as good as mineral oil, and in some cases even that would be better.
Conversion is going to be a RB26dett. Was considering a LS1 but a RB came up at a price I couldn't turn down
hey fabz i dont have your number, any luck with that turbo? the one i said i found got sold so hes my last chance or its going to be a rebuild- either that or its 1700 for a new one from another mob which im not keen on
    • There aren't boost creep issues, it's not engineered around the restriction of the cats but if you haven't tuned the engine a full decat + exhaust can flow enough air to run off the end of the OEM load scales and you will get a pretty substantial reduction in ignition timing as a result. I recommend using DFCO, avoiding ignition cut limiters, and avoiding popcorn tunes along with running a cat unless you enjoy a perpetually soot-covered and potentially burnt bumper.
    • Small update, it's been slow moving over the Christmas period with money having to go everywhere thats not my car 😅. I got myself a little present to myself from "santa" in the form of some tidy radiator mounts from fitmint automotive to get rid of the stock ones that look like they have been in an accident before and then straightened by a caveman. I know I should've replaced the rubber bush at the same time but I had no idea how bad they were until I was replacing the mounts. Decided to order their dash mat while I was at it as I feel like I am lucky enough to have a pretty decent condition dash and I don't want to risk it being ruined while it's parked in the aussie sun while I'm at work. I have found another electrical fault to add to the evergrowing list to eventually chase down. Every time I replace my taillight globe it blows within a day of use, I'm starting to think my life would be easier if I took a few minutes to learn how to use  a multimeter 😂.   Had some luck with finding a series 2 drivers headlight on marketplace to replace my mismatched series 1 headlight, a subtle difference but it's nice to have a matching set of lights now.   I returned to the air con problem due to being sick of this summer heat, found a good condition condenser to replace my leaking one! I got it in the car and was happy when I got the thumbs up that the system was now holding gas. Sadly the compressor is not kicking in for some reason, we even tried branching the relay in the fuse box. I have tried to do some research on the issue with no clear understanding of what the fix is, so for now it will be placed on the backburner until I can be bothered to look into the wiring to the compressor. The last small mods I have done was cutting the horizontal vents out of the front bar, not really in a functional airflow sense but I just think it looks better as I am not a fan of the series 2 bar. I also switched the shift knob out for a hosoboyo aluminium grex style one, it has a really nice more direct driving feel than the outdated rubbery oem one. Thirdly, I chucked on one of the ebay bonnet strut kits. The fitment is decent and they seem to work fairly well. They have only given out once while the car was parked facing downhill, I think if I was working under the bonnet I would still put the oem hood stay up to be precautionary as to avoid getting a speedy concussion.
    • Got pneumonia, haven’t played with her in a while, but I’m back now. Previous owners cut bonnet pins into the bonnet. My choice try find a replacement or spend $15 get some pins myself to cover up. Now only one small hole to cover. looks shit now, but when the bonnet is red again. Be good 🤞
    • No R32 GTSt had 15" wheels. 205/55-16 was standard GTSt fare. 4.36:1 is standard R32 turbo auto diff. I think the manual was too, not 4.11. 4.11 and 4.08 were R33 namual and auto respectively.
