Cruise Alice
Sklyn
 Share
Guest Rexlr8
Haha, cammo try'd sending me something but it was blank, and then words saying soft as berrys ass...
Righty-o... Starting working on the car at 11:00 morning and didnt f**king finish till 10:30 at night.. After not getting the job done i was in a foul mood and tired as f**k. Plus, im sure me laying down with a coke was alot better then being at the carwash cokeless and bored :worship:
Btw, Oil on and gauges working. All's gooooood!!
Will be out this weekend tho.
well ill gladly get it all orgonised either we have 11 imports and in december have all 11 cars lined up or if we have more than 11 have say 2 or 3 in each photo any ideas would be good or u can just send me the photos to [email protected] or ill come and take them for ya if anyone has an idea for a theme , a colour scheme , or what month thay wanna be in let me know.
Anyone know if there is a difference in Drivers side front quarter panel/guard between R33 series 2 and the 40th anniverssary model? Or where to get one?
My little bro just hit me.......
Calendar sounds great have sent you some pics...
He didn't really say, just said he'd rather repair it because "these bloody imports are so hard to find the right parts for"
But depending on cost to repair, I'd rather get it replaced..
yea dude dont get it boged up hyden will load it on and it will turn out shit find a guard and replace it be good to have 1 car every month then all in december if we can fit them all shotgun july u should be able to find a guared easy there always crushing 33s and can we get 11 cars together i can only think of 9
Edited by fab34
 Share
    • You all are absolute legends! Thank you for helping me put this into context with your comparisons!
    • There's probably an underlying issue with the A/C system too. I recently fixed mine, now it's fully control by the Haltech and car's factory HVAC controller  Have a squiz here:
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
