Speakin' of drags
Heard across the grape vine it's now been moved from 2nd Nov to 15th Nov due to the speedway. It's also still going to be a night run aswell.
Spot on craig. Could be another car for you to play with too.
Yes, Ive seen 2 new subes in town this week, hope they come out to the drags
Infact you all better get your ass out there, it will be a Ripper if u all show
:devil:
when is it?
Twilight meeting on the 15th November. Only a 40 dollar meet, no excuses, except maybe if you have to work or your car is in a thousand bits, then you'll just have to miss out or come and watch. Even pit crew for someone to gain free entry.
If my suspension arrives and I can get it in I might have a run,
otherwise Who Needs Some Pit Crew??
I'll have to try to get the night off work anyway, so fingers crossed...
I can't think of a better place to run in the new engine...lol...any excuse will do..
Fab,, on slicks????? he might actually try to get a good 1/4 time for a change hey?? lol
P.S.
I'm disappointed in you leigh.. :P
Hey Kurt... why did'nt you buy HYPACTIV? 14g's low 13's and its already here...sure not as powerful as some, but quick. Besides if ya get one like mine everyone will come lookin 4 me when your actin....
White 180 Boy :O
White 180 Boy :P
Because if I had bought hypactiv it doesn't come with a forged motor and I've wanted a 180 for about 2 years. Car is already paid for, pick it up on the 9th. Not looking forward to the drive. But it has climate control so it shouldn't be too bad. Who said I'll go out and act? Probably won't be able to afford petrol.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
