I will be there with both cars. R32 is now roll caged, has new OS giken R3C triple clutch and new OS giken box with HD input shaft. Trust 6-speed dog box is out to get its yearly inspection. Soon will have new tune with the 1000cc injectors and dual bosch fuel pumps done on the 25th.
V-spec will keep its current OS giken box and tune, and will have 2nd new carbon triple as INTUNE totally f*cked it up, hence why my last attempt the car went backwards. 12.4 and 12.9 I was pretty pissed off. I shouldn't have changed away from Glen and MarK at brake and clutch. Mark knows his stuff, he is really knowledgable. I'm paying for it now.
They better let me run the R32 as my 10 second passes were at a test and tune meet, so technically they shouldn't have kicked me off until I ran that time at a bracket meeting. Watch CADRA be total wankers if the car does 140mph +, it's going to be a total shitfight. If they change their mind on passing my cage then they can forget me going out to drag race ever again. It seems like it's fine for the imports to race as long as your not beating the main V8 players, if you do, then they get sooky. Really is a bit of a red neck attitude out there and I don't think they take the Japanese cars seriously at all.
I think it's more a case of the only cars running the passes that are in the 10's or better are the purpose built cars so for someone in a street car to get there has probably raised a few hairs on the back of peoples necks. Just keep getting faster BK and try do everything to the ANDRA regulations rather than CADRA. If it's at national spec then there can't be any arguement. If they do pick on something I would assume it would be for the safety of yourself and the other racers. I can understand what you are saying about running that time at a test and tune though, it should have been left until a bracket meeting before something was said. Test and tune is exactly that, testing your equipment and making any changes required.
See you out there when my new gearbox is in.
They do make up their own rules though. I can't find anywhere in the ANDRA book that says you need to secure your oil filter, and that is one of the first things they pick on you about. If you can find it tell me where and I'll stand corrected. Anyway are you going to enter the 1320x event ? If so you'll need a four point harness at SFI 16.1. ANDRA is 11's for 4 point but this meet they are inforcing 11.98 OR 110 MPH. That's you, me, ozzy, fab, craig - all over 110mph. Pretty silly I think. I'll see you guys out there after Finke to stir the CADRA pot !
Edited by BK
Oscar, how the hell did you manage the 11.7 in RWD ? That's pretty good bro. I dunno when I'll be back out now after buying this house. I didn't have any front diff or cv shafts installed anyway. Was going to bring the white car but I had to work. Blue car is still a while off being fully ANDRA legal. After looking at the calendar I'm going to aim for Aug. 16 with both cars. White car just needs a bit more of a break in with second carbon clutch and to sort out boost control issues. As I told you the blue car has got some oil and water leaks to be addressed.
    • You're not wrong, but more than a few times I've heard of people running into issues where their injector characterization isn't quite right and that approach works for that specific configuration but once they switch over to a new set they discover a whole bunch of stuff wasn't set up correctly. It's slightly more annoying to reverse engineer the OEM MAF transfer function but you already have the sensor wired up to the factory harness so keeping it around for a few weeks more while you figure out the tune is easy enough. I've seen GM also use a combination of both MAF + MAP in their ECUs before, MAF is for steady state and a calculation of the cylinder VE to correct the base VE table, then in transients it uses that calculated VE + raw MAP to determine cylinder filling somehow.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
