Oscar, how the hell did you manage the 11.7 in RWD ?
Easy exactly same procedure as AWD. Long smoky burnout, launch on limiter and hang on.
I was still getting wheelspin on the 3-4th change at over 100mph :) I'm sure if I practised more I would get low 11's
I heard something about another accident that only just missed a small pole
Another street drifters close encounter with a gutter. Heard it was suspension damage only.
Any more details yet Cameron?
I'm all set for the drags again tomorrow. :D
Anyone needing S13 parts should come & see me or pm me if you don't know me. I am still stripping Ryan's old '92 Silvia shell and there is not much left.
Best bits available would be the front seats, all glass, rear subframe complete, minor interior parts and shell rear of the A pillars.
What ever is left in a few weeks time will be going to the wreckers or crusher. All cheap especially if you want to take the bits off yourself.
Dunno if you guys know yet but its $100 to enter the 1320 event. i wonder why the price hike?
What do you mean ? Dudes are coming from the US and you think it's gonna be like an off street meet ? Bracket racing in super street is about as expensive as that normally if you don't have a s/st ANDRA license, and even more expensive in super sedan ($125 + license). And it's $80 if you nominate now, $100 on day. It will be extra to have a one day license too.
I'm wondering how strict the scruteneering will be. If they are relaxed about it that will really piss me off as the only reason I'm not racing is because of ANDRA rules. Both cars are ready to rock mechanically but R32 still needs battery isolator, fit new 5 point seat/rail, 5 point harness, side intrusion bar on cage, tailshaft loop, new race gear, $9 a litre unleaded, upgrade to group 3 unlimited ANDRA license, parachute yada yada yada. It just goes on and on. I just need to get the R32 back out there to see where I'm at. You guys have no idea the money that's been poured into my GTRs. (could've had an R35 already put it that way) :)
Good news for this event is tail shaft loop is only required in the 10 sec zone (ANDRA says 11) but harnesses will be enforced in the 11 sec zone OR 110 mph. I've tried telling everyone - don't say you were not warned.
I spoke to Andrew Cole today over the phone and scrutineering won't be any different to any other meet. So whatever you normally do to prepare your ca for racing is what will be required on the day. Hope to see you out there Ben.
the weekend was good with lots of good races, carmelo was running strong all day after the snapped axle.
i had my car on the dyno the other day to see how the afr are so here is the dyno sheet....... its running at 10:2 AFR so it really rich but should be getting that sorted when dr.drift comes up.
i am pulling this turbo off soon to send back and be updated to a more responsive turbo
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
