Josie has put up some photos on the cadra site from last week. The CG's crew is well represented!
Pity I didn't hang around on the night, seems I won the best burnout again.
http://www.cadra.com.au/index.php?option=c...e&Itemid=16
What are you guys a gang or something ??? Proud to say I ain't part of no crew, just a 65 year old and me. Catcha first meet and have a happy new year everyone !
Edited by BK
  • 3 weeks later...
  • 4 weeks later...
I'll be there first meet. Thinking of giving the drags away though, it's a bit of a mugs game for the amount of money it costs to get quicker, track time ect. I am serious about getting my 9 sec pass though, if they don't stop me from doing so first. A mid 9 at 140-145mph should be in the ballpark for what it's capable of on full noise. Specs of engine are:
Rebuilt HKS T51S with 1.00 exhaust A/R(was a bit tired) using the Trust 48mm external gate
New Trust 8 litre sump complete with baffling, extended pickup and with secondary oil return line from rear of head to sump
New RB26 front diff crown and pinion gears
New Tomei 1.5mm oil restrictor between head and block
New RB26 block oversized 20 thou(86.5mm bore)
New ARP main stud kit
New Crower conrods with crower rod bolts and oversized gugeon area
New CP low silicon content non-cooling channel type 86.5mm pistons, rings and oversized gudgeon pins
New ARP head stud kit
New ACL race series big end bearings - standard size
New King main bearings - standard size
New Tomei 1.2mm head gasket and Tomei throttle, intake, exhaust manifold gaskets
New Ross tuffbond harmonic balancer
New Nitto high volume/pressure oil pump (these are the shit !)
New N1 water pump
New R34 GTR crankshaft - crack tested and balanced with entire rotating assembly as one to handle 10000rpm
(that's balancer,crank,rods,pistons,clutch,flywheel all balanced together as one unit at Rick Corbett engineering in SA)
And that's just the bottom end !
Head specs are:
My original head casting which was already modified in Japan extensively (don't fix it if it ain't broken I guess)
My existing Apexi Step 3 camshafts (8.7mm 280 intake, 9.7mm 280 exhaust) with original cam bolts
Existing OS giken cam gears setup in Japan (haven't touched the timing setup)
New RB26 intake and exhaust valves (lapped into head by the master)
New Tomei 9500rpm rated intake and exhaust valve springs
New Tomei titainium valve spring retainers and collets
New bronze valve guides
New precision shims RB26 lifter shims to reset valve clearance
Then there's the rest of the shit in between which I can't be bothered going into
I originally bought a short motor from Perth but the machining and assembly sucked ass from a performance shop with a very high pedigree. Wasted like $3000 - $4000 in machining and labour on them. Just shows you why I trust no one now and have the highest respect for my engine assembler. No one in this town will assemble an engine to the exacting standards to which I have witnessed - no one.
I will be babying the car for a while though - no dog box, BP 98 fuel on a conservative tune with lowish boost (24psi) and 8500 limiter for first meeting, then I'll crank it back up to 9500rpm, 30psi, Trust dog box and VP109 unleaded. Thinking about entering both cars at superlap in eastern creek in May, it'll be way more fun than quarter crap. Looking at entering the R33 in clubsprint and R32 in open class. Just to drive the 32 at full noise will be awesome round a track, and will give me more info on how to set the car up for circuit work (probably need to run the street tune power wise - I'm sure 450kw + at the wheels BP 98 tune will do)
Anyway look out for the new and improved R32 GODZILR driving around about a week after new year
(albeit looking like a dickhead trying to drive on the street with the OS giken R3C triple plate clutch smoothly!)
Edited by BK
Multi plate clutch should be fine on the street. Just stopping and starting will take some getting used to.
I can understand where your coming from by wanting to get involved with other forms of motor sport, but don't exactly see where your coming from with the whole quarter stuff is crap. It is a different discipline of driving and being consistent is a lot harder in rwd car on street tyres. Which half the appeal for me.
Be interesting to see if the track here holds enough traction for a 9 second pass after nearly 6 months of rest.
I have driven this clutch before mate, that's what I'm saying. It's a prick of a thing for cruising, but I didn't buy it for that.
Coming from over 15 years of racing motocross and supercross interstate, going in a straight line is bloody boring. I don't care if I was in a car doing 6 second quarters, it's still boring. Yes I like acceleration and it is satisfying when a run all comes together, but it's a lot of cost for very little exitement factor. Choosing corner lines, corner exit timing, braking distance into corners, carrying corner speed ect. has a 1000 times more skill involved than drag racing - especially if your driving a car RWD, slicks, transbrake with a properly setup auto. May as well have a chimp at the wheel. All the skill goes into car setup - not actually driving. Manual cars take more skill but it's a handicap for drags anyway.
The only reason I want to get into the 9's is to prove that's what the car should be capable of to myself. To prove that a privateer not a workshop built and funded car can be competitive against Australia's best GTRs. A 9 anything will be a huge achievement with a H pattern - only a handfull have ever done it in a GTR. Theo Wollett is the H title holder at 8.99 at a massive 160 mph using a PPG 5 speed dogbox.
Edited by BK
But just because the option of slicks and transbrake and auto are there doesn't mean you have to take it. That is why I've been running my 180sx street tyres only and still manual, just to improve my driving skills and understanding of the car more. Sure you might find it very little gain for the money spent, but that is what you get trying to compete at a level restricted to major sponsored workshops. You didn't have to go that far, but hey if that's your choice then I wish you luck.
I wasn't disagreeing that circuit or time attack or even tarmac rally weren't more exciting, just that none of these are an option in Alice Springs so drag racing, rally sprint or speedway is the pinnacle of motor sport here.
As for multi plate clutches, I am fully aware of what they drive like as I have one in my 180sx and I drive it daily. It also has a very tight 2 way LSD and it makes it rather jumpy in car parks or confined areas but I still drive it on a daily basis. Because I can.
    • I like mine. Much better than stock. Like i said before the reverse/parking cameras look even worse than normal, still useable. When you buy one make sure it's the latest version. Heaps of cheap ones that run the old hardware and software. Got mine from AliExpress. Mine is quick no lag, boots up 1-2 sec. Menu is fast. Netflix is fine and so is YouTube. Android Auto is random taking 3sec to 15sec. Most of the time it's quick. Very rare it doesn't connect. But that could be a phone thing.   Now I think they use a Pixel 3XL to run this whole thing which i guess is fine, but the problem is that some apps will not work on old hardware like Disney Plus  Maybe Prime Video too 🤔. they will not update. Iv'e tried getting the APK Disney + but i still couldn't get it working. I have a Data sim installed so i have internet all the time. You can't Hotspot off your phone and connect Android Auto at the same time. Not that you need too, if you want you can hotspot off your phone and run any internet map app (google maps) and you can run the Spotify app on it's own (the app runs better than android auto) You can still access the INFINITI intouch system for all the o.g stuff    P.S i got new non Polarization Sunglasses too 😎
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
    • I specifically said buy new performance car because of the use case here (i.e, no track use and fun livable everything/do it all easily if not especially amazing as a drivers car). Tracking an 80K Skyline and an 80K M2 makes the BMW the obviously more risky purchase WHEN something goes wrong you suddenly can't easily fix it with hand tools and readily available parts that you may have a community of people you know available, or years of your own knowledge on the platform to apply. There's reasons you see Hondas and Vettes and RB's and Miatas and such at tracks, you can easily hand-tool repair 99.9% of it in a shed, usually with the tools and the skillset of the owner to apply to it. An i30N is not going to beat a R chassis unless it's got massive problems either. The old cars can, and still do work great. The problem is - and always has been - social media would have you believe it's simple and easy to achieve the results you see online.  People want their car to be like "one of those cool JDM cars" which is the default image people have when they think of  "cool JDM cars" You are paying 25 years of catchup R&D to achieve. Or the knowledge somebody else has to do it for you, which is big dollar restomod stuff.  The bar has been moved and every R chassis that people see/like/enjoy has 25 years of R&D thrown at it, or is owned by someone who did all that work and has that knowledge over the past 25 years. All the survivors have been progressively resto-modded the entire time. OR you slowly bring it back to how it was stock. Which is also prohibitively expensive, done for the love of it. This is what the JDM community is now. This is fine, but "Where do I start?" is either: 1) Don't 2) Take your own slow journey but you cannot compare your progress with others who have had 25 years of R&D and experience building their own cars unless you pay for it.
    • Yep, with the crazy inflation of the value of our cars these past couple of years this became a problem for me too... My solution is to transition to bikes. Everything feels so cheap compared to tracking the skyline lol
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
