is it possible??
ive seen some makes like ferrari lamborghini on the raws lists but i dont see and BMW or Merc..
I wonder how hard it would be to set up a business importing them into australia?
raws doesn't descriminate based on country of manufacture. so it's exactly the same rules as importing japanese cars. or russian cars. or mexican cars. :P
an import is an import. and there are places that bring in some euro cars but the typical euro car buyer doesn't want a second hand imported car with no known history.
I always thought because Lambo and Fezz were both imported in small numbers they have always been imported and complied under the low volume scheme by the Australian distrubutors?
LHD would be the most common problem with the coolest of euro cars also.
RHD examples of all modern euros except maybe for porsche are easily accessible here in japan..they are plentiful.
i get the sneaking suspicion only models made prior to 1989 are eligible for import approval..
Yeah right I didn't think Japan got much RHD euro stuff, I thought it was mainly LHD.
For things people would want to buy like BMW M or Benz AMG ect all come out in Australia new so would be excluded from SEVS.
whats the average price for a Ferrari 360 in RHD? i could only find LHD examples. from what i've found the LHD stuff goes for around $150k-$250k still cheap for a 360
you're thinking about this all wrong. again, DOTARS doesn't care whether a care is euro, jap-o, hindi, pakistani whatever. the rules apply the same to any manufacturer.
they are all listed somewhere here but basically you cannot import a vehicle if the same or very similar model was sold here in full volume. if the model you want to import was not sold in full volume then sure you can import it providing you can have it added to the SEVS register. To be added to the SEVS register there are certain requirements it must meet (be unique, performance level, equipment level, magazine featured etc). Then to comply it you must be a RAW or get a RAW to do it for you.
again, it's nothing to do with 1989 etc. There are 3 main ways to import any car into australia (again doesn't matter where from). Personal import. 1988 and earlier model cars and lastly SEVS.
i understood the 3 methods. obviously one of the ways im going to do it is to have a private import but starting a business is also on the list of things to do.
Having a car added to the sevs register doesnt involve anything like smashing the car to prove its safety, does it?
I think you need some reading time on DOTARS website. it will guide you through the process. :action-smiley-069:http://www.dotars.gov.au/
just remember any model of car that was sold here in full volume cannot be added to the SEVS low volume register. so forget 3 series BMW, 5 series BMW, CLK mercs, SLK mercs, etc etc.
ferrari's and lamborghinis are already on the SEVS register as this is how the manufacturers chose to import them into AUS.
 Share
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
    • Is the RB26 actually that far off the mark? Honestly from where I'm sitting a VR38DETT is not actually that much more advanced than the RB26. Yes, there is a scavenge pump on the VR38, it's smarter in a number of ways but it's not actually jumping out to me as alien technology. Something like a B58 or V35A-FTS on the other hand has so many surprising little design features that add up to be something that just isn't comparable.
