Hey guys I have a question. I am keen to have my ecu rechipped, with nistune
but I also have a ecutalk v2 display, I was wondering if the 2 were
compatible and if my ecutalk display would still work after having nistune installed.
I have done several searches on google and various forums and I have been unable to find any info. :laugh:
any help would go a long way thanks.
https://www.sau.com.au/forums/topic/181930-nistune/page/11/#findComment-5170133
hey ppl, might be a silly question but does nistune use an afm?? eg, if wanting to upgrade to a z32afm, is it needed or not??
cheers
If someone was to make a map sensor replacement module for the nistune/stock ecu would there be much interest in something like this?
It can certainly be built but if theres no interest I won't bother researching it.
https://www.sau.com.au/forums/topic/181930-nistune/page/11/#findComment-5170937
already looked into this. Should be very simple, read in map sensor values read in air temp sensor add correction factor output 0 - 5v signal back to the ecu. Main thing would be the need for a complete retune of entire map, but this effort could be minimized with extensive logging of afm and map values in parallel(Similar to the holden MAFless tunes). I believe some one has also used TPS as loading on an NA Vl commodore using nistune
Edited by Crans
https://www.sau.com.au/forums/topic/181930-nistune/page/11/#findComment-5170950
Yep if you did no correction and just made sure it was linear in the range used from 0-5v it would still be very easy to tune.
Ah so many ideas and so little time. Need to get my car running and buy a decent oscilloscope so I can finish the VCT controller I've been carrying on about.
https://www.sau.com.au/forums/topic/181930-nistune/page/11/#findComment-5171022
I have done several searches on google and various forums and I have been unable to find any info. :P
I can confirm my ecutalk v2 display (and 1.3.x windows software) work fine in my nistune'd R32 GTR. love the new 2.02 firmware with the user-configurable alarms and am gagging for the eventual logging to micro-sd.
https://www.sau.com.au/forums/topic/181930-nistune/page/11/#findComment-5173040
hey guys i just bought a r32 gts4 and was thinking of doing the nistune upgrade for the ecu, but i want to change it to a manual as well. would i need to get a manual ecu or a gtr ecu? or would it be fine once the daughterboard is installed? don't wanna upgrade then find out i need a new ecu lol.
https://www.sau.com.au/forums/topic/181930-nistune/page/11/#findComment-5175332
the daughterboard can be reprogrammed for different ROM images. bascially we can put a manual program in auto ECU no problems
GTR ECU is completely different you wont be needing that in a GTS-4 unless doing an RB26 transplant with twin AFMs
https://www.sau.com.au/forums/topic/181930-nistune/page/11/#findComment-5176244
Are the daughterboards for 32GTSt and 32GTR the same?
Reason I am asking is I am looking at Nistuning my 32gtst but if I max out my z32 afm, I am wondering if I can swap the daughterboard in to a 32GTR ECU and get a GTR image loaded on there ? (and then run a GTR engine harness and twin afm's)
https://www.sau.com.au/forums/topic/181930-nistune/page/11/#findComment-5176335
Wanting to buy a board and tunning package to have a play with.
Any one else using it? What do you think f it?
How do you buy it? Ive sent emails no one answers
I bought and installed my Nistune daughterboard direct from the guys that make it.
It is installed in my S13, and was tuned by Mark @ MRC dyno in castle hill. I haven't had any issues with it, and for the price i think it is an excellent option.
https://www.sau.com.au/forums/topic/181930-nistune/page/11/#findComment-5176539
got a question for ya's
i have a type 4 daughter board in my r34.
I know that the daughter board has its own EEPROM that we can change the values in while tuning in nistune software. And the original ECU's EEPROM stays unchanged, we just tell the ECU to read from our new EEPROM. Is this correct?
If this is correct, could i tune my car on pump fuel 98, then take the hex file from the daughter board's EEPROM and burn it into the original ECU's EEPROM, then re-tune the daughter board as usual on e85 fuel? then i just have to run a couple of switch wires from the jumper pins on the original ECU to the dash and i have instant capability to drive on either fuel.
But is it even possible to burn a new image into the original ECU?
and can anyone see any major flaws in my idea?
https://www.sau.com.au/forums/topic/181930-nistune/page/11/#findComment-5176589
    • have you rotated the car yet? if so how smooth was it?
    • And finally, I had the driver's side airbox off while adding a long drain hose under the oil can to down near the oil filter. Doesn't look good, it has definitely had an turbo oil seal leak and looks like it has been for a long time.....guess I'll have to get a pair of highflows to put on the shelf It's also worth mentioning it has a really strange clamp between the bottom of the airflow meter (which has a big barb/lip on it) and the intake pipe. I've used the magic of MSPaint to show, basically you have to clip out those 2 steel springs which unlocks the hose from the AFM. I used 2 flat screwdrivers, the spring sort of clips into the unlocked position. Reassembly you just pop them both back flat once the hose is far enough up the AFM that the spring clamp is above the barb. Weird to use but much more convenient once your'e used to it compared to trying to do up a hose clamp under the airbox like on 32 GTR
    • The other thing I started was a fire extinguisher bracket.  As with a few other cars previously (350z, Leaf), I'm going to add a bracket between the navigator seat's front bolts, then mount the extinguisher on that. Unfortunately Nissan (probably the same engineer who did the A/T fluid interwarmer) decided that the front seat brackets would be recessed and uneven so the bracket shape was a bit tricky; I ended up doing 1 part under each seat mount (the large hole is because there is a flange under the seat mount to allow for the carpet thickness)   and then a horizontal part between those 2 No final pic yet as the paint needs to dry, I'll post up once that's done
    • OK, a few half jobs on the skyline this weekend because its booked for a test day at Wakefield Park on 27-Feb. While the Ecutek dongle and app provide display and logging of a heap of engine parameters, they annoyingly don't have access to the auto trans temp. So I grabbed an oil temp gauge from Raceworks which apparently has warning colour change and peak hold, about $95  and their 8mm hose sender adapter Now, I foolishly thought these 2 might work together, but no, the sender needs about 30mm clearance in the fitting and the adapter only had about 8mm. I've cobbled something together with an NPT T piece and blank for now but will try and work out something more permanent as I intend to use the same fitting for the data logger in the future. Under the car, Nissan's engineers decided that only one opportunity for coolant and trans fluid to mix (the radiator) was not enough, and they also added an interwarmer near the sump on the passenger side like the engine oil has: I've cut the hose between the auto trans outlet and the interwarmer inlet and inserted the sender there as that gives the best indication of temp inside the transmission.   From there it is back to the pain of running that sender wire to the cabin, I've run it up near the passenger headlight, into the battery box, across the channel at the back and into the master cylinder area where I ran out of wire length (and patience). Remainder of the job is through the grommet near the accelerator pedal that I've used previously, then across under the dash to where I will temporarily mount it on the console for track days (and remove it other times). The gauge will also need IGN, BAT and earth (I'm not going to worry about illumination as I'll unhook it between track days)
    • This piece is obscenely discontinued. I honestly hate the frameless window design because the rubber gets stressed and the guides as well every time you open and close the door.
