Guys it was my bad about the information provided to the workshop mentioned in this thread with regards to compatibility since I mixed up the model numbers. Usually I refer to the Nissan vehicle designation (WC34) rather than trim codes
RS4 Series 1 and 260RS cannot be Nistuned but RS4 Series 2 (with RB25DET NEO) can be. Anything which has ECU part number 23710-0V8xx in it can be done with Nistune Type 4 boards. Hope that helps
Edited by darkhalf
  • Like 1
https://www.sau.com.au/forums/topic/181930-nistune/page/18/#findComment-5669785
  • 4 weeks later...
You emailed me this q over the weekend? Not replied yet but only VLT, S13 CA18 and HCR32 currently have knock reporting active
Other models dont yet because I have to dig through Nissan/JECS code to find the memory locations where knock is recorded and add extra code to spit it out the consult port. Currently BNR32 and Z32 have identified locations but cant seem to get it working yet
So your knock count will be zero. I'm going to hide this gauge to avoid future confusion
As for the 'consult guages' not appearing, check under 'windows' menu and cascade them in case its hiding off screen for some reason
https://www.sau.com.au/forums/topic/181930-nistune/page/18/#findComment-5714473
yeh hehe
consult gauges work, thats the window we had open during tuning, but the multiple consult gauges only opens 3 windows, inj duty, knock count and TP..
when i first got it and had the consult plugged in, the multiple gauges were working
https://www.sau.com.au/forums/topic/181930-nistune/page/18/#findComment-5714915
Havent read anything in this post for a long time but i thought i might input this:
Ran a RB31/26DETT without problems.
R33 GTST S1 harness without VCT hooked up
Q45 Throttlebody
Twin Q45 AFMs through Apexi SAFC-II (2 in 1 out with average output)
1600CC injectors through GTR resistor pack
R32 GTR coils
and much more..
While it was beeing built:
Worked a treat, sad to see the engine gone, sold it some months ago.
https://www.sau.com.au/forums/topic/181930-nistune/page/18/#findComment-5715246
How accurate is the 'timing' displayed in the nistune consult gauges for setting base timing ??
That's like getting a blank ruler, randomly drawing a centremeter mark on it then going how accurate is it for setting the base cm mark on other rulers....
https://www.sau.com.au/forums/topic/181930-nistune/page/18/#findComment-5724244
It is as close as it gets .. given that you have aligned the timing mark on the crank pully with what Nistune displays ..
https://www.sau.com.au/forums/topic/181930-nistune/page/18/#findComment-5724378
  • 4 years later...
Whats the max hp the Nistune type 4 can handle. Is it suitable for a 30 25 neo with gtx3582r freddy plenum 1000cc injector hpx1 airflow meter.
Will it be up to the task
Scroll back a bit ^^ to Brother Davids's set up - reckoned it was ok at 700hp
https://www.sau.com.au/forums/topic/181930-nistune/page/18/#findComment-7691640
HP is relative to the AFM, however using those HPX ones inside of a 3" pipe will give you the resolution needed.
Just need to be smart with the TP Load scaler :)
I love Nistune, especially with the feature pack. Launch and flex support, albeit I've yet to setup a car with the flex support on it. Should have one of the Nissan Silvia boys doing it in a few months.
https://www.sau.com.au/forums/topic/181930-nistune/page/18/#findComment-7691755
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
