After more discussions with the tuner, he called Matt and the reason behind the drop in communication is that there is too much electrical noise and the ECUtalk cable is the issue?? Tuner mentioned that it took him 30mins to change one section of the fuel map in between drops in communication... Now Matt suggested another cable probably the plms? one ($100) and problem solved. I paid $80 for the ECUtalk cable and it has, and I quote the tuner, taken 13hours on the dyno to get a raw tune!!!
I can't believe this shit... Needless to say the car won't be ready until Monday when the cable gets here and I swear it better not take long to get the final tune on it!
It took your tuner 13 hours to realise that the cable was dodgy? He better not be charging you the $200 an hour you quoted for that!
https://www.sau.com.au/forums/topic/181930-nistune/page/16/#findComment-5497008
Probably 13 hours is the whole time added up so far which seems excessive
Initially they had write issues because of board installation probs causing errors, and after that the invalid license stopped further tuning, and after that problems with the electrical noise slowing the connection. He was trying to tune whilst it kept slowing down/dropping out because we didnt realise it was having noise issues. Trying to diagnose over the phone can be a bitch ...
If everything is done properly then there are no probs, but this time around has been multiple points of failure with the setup
https://www.sau.com.au/forums/topic/181930-nistune/page/16/#findComment-5497081
It will be interesting to see how it goes with your nistune cable, i have one of yours and it is perfect everytime on every car. The only time ive ever had issues is with a 3rd party cable when out helping mates with home tunes etc...
i would bet it is the "other" cable causing issues.
https://www.sau.com.au/forums/topic/181930-nistune/page/16/#findComment-5497099
I am using the BLAZT cable (I bought that before I was even thinking Nistune), it works but has issues every now an then.
So when recording a longer log it is mostly a matter of minutes till the connection gets interrupted.
I would recommend buying the cable from Matt, it's money well spend and saves you much headache ..
https://www.sau.com.au/forums/topic/181930-nistune/page/16/#findComment-5497202
  • 1 month later...
CRD wants around $1500 installed and tuned
That sounds excessive. I got my nistune supplied, installed and tuned for 770 in my r34 GTT. Dunno if the GTR's are a lot harder to do? Also depends on mods you have done i only had the basics such as FMIC, turbo back exhaust and boost controller
https://www.sau.com.au/forums/topic/181930-nistune/page/16/#findComment-5553735
hmmm
as for my performance mods go, only got aftermarket exhaust front pipes, 3" hi flow cat and catback, air pods and profec b @ 14psi...
if anyone knows a more reasonble place in sydney please let me know !
cheers
https://www.sau.com.au/forums/topic/181930-nistune/page/16/#findComment-5553915
Yeh much the same as me, I got mine done for $550, bought the board for $200 so all up was $750. But my tuner told me mods won't affect the price at all unless they are done badly.
https://www.sau.com.au/forums/topic/181930-nistune/page/16/#findComment-5553997
Depends on the value you put on your engine, CRD are known to do good work and can charge accordingly..... Tuning is a fluid thing and can be done good bad or everything in between and the prices generally reflect that.... it also keeps the shit out of your shop.
https://www.sau.com.au/forums/topic/181930-nistune/page/16/#findComment-5554007
Agreed - tuning costs are also based on time spent. Doing the mapping for a quick power run is obviously going to take less time than carefully going through everything including idle and off boost drivability
With regards to cables swapping the customers ECUtalk cable for a PLMS one was reported by the tuner to work perfectly afterwards with no drop outs
Last week we put my R34 GTT on the dyno (just got cams fitted... squeezed 301rwkw @ 18psi out of the GT3071R) and was running with a blazt USB cable. We were experiencing several disconnects in the higher rev ranges, so swapped in the PLMS cable and no more dropouts on subsequent runs
I just have to point out that most of the cables out there were based on the original serial version PLMS schematic that was made available to the public and then add a FTDI USB converter chip on top. However Pete has spent many hours since on the dyno and using scopes etc to monitor, isolate and filter the noise which is why there is a significant improvement with data stability in the later version USB cables which have come out
Whilst most cables will work fine for your normal consult display apps (apart from ROM download) where data integrity is important, there is a requirement for nice clean comms signals from the consult port (this includes good grounding on vehicle also)
https://www.sau.com.au/forums/topic/181930-nistune/page/16/#findComment-5557041
Hi people,
I've got an R34 GTT tiptronic and want to get a Nistune board and a proper dyno tune. The catch is, I am also looking at doing a manual conversion later on.
Can anyone confirm if a manual conversion requires an ECU swap? Or can the car be run with the auto ECU with just the auto 'logic' disabled?
And what's the go with Nistune, I understand the board is not transmission specific but what about the tune? If I was to retain the auto ECU after the conversion, would the board or tune need to be tweaked to support the manual box?
Thanks guys.
https://www.sau.com.au/forums/topic/181930-nistune/page/16/#findComment-5557688
Dont see any problems still running AT image on the board with the manual trans, except you will get AT fault codes.
Since AT/MT should have no difference with fuel/timing maps etc (Trent correct me if I'm wrong here) then tuning shouldnt be affected
Other tables like injection limits, fuel cut/recovery will be different between AT/MT
I would suggest when it comes to MT conversion to get the board reflash the board to a MT image and copy the main maps over from the AT tune
https://www.sau.com.au/forums/topic/181930-nistune/page/16/#findComment-5564063
Awesome, thanks Matt.
So it sounds like I should be able to continue using the original auto ECU and the Nistune board after the conversion, and just get the tune tweaked for manual transmission? Sweet!
Edited by V28VX37
https://www.sau.com.au/forums/topic/181930-nistune/page/16/#findComment-5564593
  • 1 month later...
Is my ECU nistuned? lol weird question I know but apparently my ECU is... here is a pic of it. Dont know what the board is on top of the unit upside down?
I also need to know who does nistuning around gold coast area or north coast my car is running like a 3 legged goat atm :(
https://www.sau.com.au/forums/topic/181930-nistune/page/16/#findComment-5615290
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
