Ok well thats good and bad news :( Good news its actually chipped bas news its not nistune :(
So how am I able to tune this ecu? I was going to buy a consult cable but now it looks like my ecu is not easily tuneable
Does anyone know who chipped my ecu? like what brand or whatever? cheers for all your help
No it doesn't have a nistune. I has been chipped though... Its got a socket with UV eraseable EPROM
https://www.sau.com.au/forums/topic/181930-nistune/page/17/#findComment-5615513
the same way any other chip is done, find someone with a chip eraser etc, its crap though takes ages to get any real changes, just fork out for a nistune, about $300 installed usually and maybe 2-800 for a tune depending how many mods, if its basically stock they prob have a good base map and only need 30mins touching it up.
https://www.sau.com.au/forums/topic/181930-nistune/page/17/#findComment-5615943
Question.
Will a map burnt to the Nistuned ecu be wiped if you disconnect the battery terminals (i.e. the method for resetting the factory ecu)?
No, just like the factory one it will simply revert to the programmed maps, deleting any self adjustment the ECU had made to fuel and ignition maps.
https://www.sau.com.au/forums/topic/181930-nistune/page/17/#findComment-5621785
Question.
The factory ecu doesn't really learn much, it has a knock map and a normal map, all you really reset is the ecu flags which if accurate will be restored on reset anyway.
So no it doesn't reset anything more than it currently does.
https://www.sau.com.au/forums/topic/181930-nistune/page/17/#findComment-5621909
I received my nistune stuff last week :)
When you order it they ask for ur ecu number on the casing, Now is this to put a stock standard base tune on the chip?
So if I install it, would the car drive/idle like the stock ecu ? Is this fine for the car?
Or is driving around with the nistune chip in the car before it gets tuned a big no no?
https://www.sau.com.au/forums/topic/181930-nistune/page/17/#findComment-5638520
They ask for ecu number incase you have an ECU they haven't seen before or can't use (R33 GTR ECU for example), the stock map is pre-loaded (100% the same as the factory map) and will be exactly like driving with an unmodified stock ECU.
https://www.sau.com.au/forums/topic/181930-nistune/page/17/#findComment-5638545
Be like you hadn't done anything to it, they will load a stock map on for you, if it was the wrong map or untuned there is a high likely hood it wouldn't even idle so you couldn't do much damage.
https://www.sau.com.au/forums/topic/181930-nistune/page/17/#findComment-5638548
  • 3 weeks later...
Matt, I think one our WA guys has been given a bum steer.. I know you do board for auto series 2 Stageas and I was fairly certain you do board for manual series 2 Stageas (RS4S) however he received this reply..
Hi Mike,
Thanks for contacting ***.
The Nissan Stagea RS4S Series 2 with manual transmission has an ECU which is currently not supported by NIStune Software.
Feel free to contact *** should you have any further questions.
Pretty sure he has a 0V801 ECU, can you please confirm? Would have sent you an email but I'm at work :P
https://www.sau.com.au/forums/topic/181930-nistune/page/17/#findComment-5665967
The guy has been misled. MT SII RS4S is supported by Nistune for more than 3 years now.
I'm using exactly 0V801 ECU with nistune and have a mate here who's using Type 4 board programmed with 0V801 image in his AT ECU. Neo ECUs are actually interchangable - I was running RWD R34 ECU (AA500) with my Stagea motor for two months with no problems at all.
https://www.sau.com.au/forums/topic/181930-nistune/page/17/#findComment-5667436
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
