Guys it was my bad about the information provided to the workshop mentioned in this thread with regards to compatibility since I mixed up the model numbers. Usually I refer to the Nissan vehicle designation (WC34) rather than trim codes
RS4 Series 1 and 260RS cannot be Nistuned but RS4 Series 2 (with RB25DET NEO) can be. Anything which has ECU part number 23710-0V8xx in it can be done with Nistune Type 4 boards. Hope that helps
Edited by darkhalf
  • Like 1
https://www.sau.com.au/forums/topic/181930-nistune/page/18/#findComment-5669785
  • 4 weeks later...
You emailed me this q over the weekend? Not replied yet but only VLT, S13 CA18 and HCR32 currently have knock reporting active
Other models dont yet because I have to dig through Nissan/JECS code to find the memory locations where knock is recorded and add extra code to spit it out the consult port. Currently BNR32 and Z32 have identified locations but cant seem to get it working yet
So your knock count will be zero. I'm going to hide this gauge to avoid future confusion
As for the 'consult guages' not appearing, check under 'windows' menu and cascade them in case its hiding off screen for some reason
https://www.sau.com.au/forums/topic/181930-nistune/page/18/#findComment-5714473
yeh hehe
consult gauges work, thats the window we had open during tuning, but the multiple consult gauges only opens 3 windows, inj duty, knock count and TP..
when i first got it and had the consult plugged in, the multiple gauges were working
https://www.sau.com.au/forums/topic/181930-nistune/page/18/#findComment-5714915
Havent read anything in this post for a long time but i thought i might input this:
Ran a RB31/26DETT without problems.
R33 GTST S1 harness without VCT hooked up
Q45 Throttlebody
Twin Q45 AFMs through Apexi SAFC-II (2 in 1 out with average output)
1600CC injectors through GTR resistor pack
R32 GTR coils
and much more..
While it was beeing built:
Worked a treat, sad to see the engine gone, sold it some months ago.
https://www.sau.com.au/forums/topic/181930-nistune/page/18/#findComment-5715246
How accurate is the 'timing' displayed in the nistune consult gauges for setting base timing ??
That's like getting a blank ruler, randomly drawing a centremeter mark on it then going how accurate is it for setting the base cm mark on other rulers....
https://www.sau.com.au/forums/topic/181930-nistune/page/18/#findComment-5724244
It is as close as it gets .. given that you have aligned the timing mark on the crank pully with what Nistune displays ..
https://www.sau.com.au/forums/topic/181930-nistune/page/18/#findComment-5724378
  • 4 years later...
Whats the max hp the Nistune type 4 can handle. Is it suitable for a 30 25 neo with gtx3582r freddy plenum 1000cc injector hpx1 airflow meter.
Will it be up to the task
Scroll back a bit ^^ to Brother Davids's set up - reckoned it was ok at 700hp
https://www.sau.com.au/forums/topic/181930-nistune/page/18/#findComment-7691640
HP is relative to the AFM, however using those HPX ones inside of a 3" pipe will give you the resolution needed.
Just need to be smart with the TP Load scaler :)
I love Nistune, especially with the feature pack. Launch and flex support, albeit I've yet to setup a car with the flex support on it. Should have one of the Nissan Silvia boys doing it in a few months.
https://www.sau.com.au/forums/topic/181930-nistune/page/18/#findComment-7691755
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
