  • 2 months later...
hey everyone,
will be getting a nistune set up for aftermarket computer tuning for my r33 gts-t, rb25. it is getting done on the gold coast so if anyone wants info on location and who to call let me know. and if anyone has a z32 computer for me that would be muchly appreciated too.... :P
smidy
https://www.sau.com.au/forums/topic/181930-nistune/page/6/#findComment-4484789
  • 3 weeks later...
Do you have a nistune for the R34 gtt auto Neo 6 Rb25det?
please say you do???
Nistune sure do....
We have done 3 neo 34 auto's now. Doing more mod's on "sammy34" atm, hi-flow turbo, 550cc inject, Z32 AFM.
Getting to the dyno today. let you all know how it went.
https://www.sau.com.au/forums/topic/181930-nistune/page/6/#findComment-4515552
Nistune sure do....
How much the nistune roughtly cost?
I got the same mods except, hybird t04e. with stock AFM
https://www.sau.com.au/forums/topic/181930-nistune/page/6/#findComment-4515833
I think i payed just under the 1g mark for mine including dyno time. Great computer, guys putting them together down at EFI know what there doing as well. Dont think id go anything besides nistune enles you were chasing rediculous number for a street car.
https://www.sau.com.au/forums/topic/181930-nistune/page/6/#findComment-4516264
interesting piece of kit
how do these compare to PFC beside the fact they dont have a hand controller?
similar league?
Nistune setup is tuned from the diagnostic port in driver side cabin fuse box, advantage of it is having the stock ecu diagnostics, whereas (i dont speak from experience) with the PFC setup it's harder to diagnose problems. Also my preferred workshop in SA (Boostworx), Nistune is cheaper to tune than PFC.
https://www.sau.com.au/forums/topic/181930-nistune/page/6/#findComment-4516945
They also retain all of the factory features like cold start etc.
only disadvanteges I know of as to date or as far as I understand are on the RB25 Neo. U cant use Nistune if your putting on an aftermarket plenum, nistune cant compinsate for loosing the traction control system attached near the throttlebody and it locks the car into third. So really I guess the main reason im using the Nistune is because it retains the standard auto computer. Change the plenum = change the computer, change the computer you need to rebuild the gearbox and install a shift kit. :devil:
https://www.sau.com.au/forums/topic/181930-nistune/page/6/#findComment-4518161
I am tuning a NISTUNE board for a friend. Though its CA18DET engine.. It is really awsome, and to that price tag i has! Great!
Only trouble is the feed from LM-1 acts up when logging in the software.
Mark or Matt or whats his name, is working on a software update. But otherwise its really nice! And easy to mount.
We changed injectors to some big 660CC, did some correction, and car startet up first time. Took 5 min to get the car to idle perfekt.
If I had know about it when i had my CA18DET engine, i would have used it. But went on to Apexi FC with the RB25DET, and now moved on to a ViPEC
https://www.sau.com.au/forums/topic/181930-nistune/page/6/#findComment-4518347
at the moment i'm running only nistune on a complete stock set up in my r33 gtst and even just having the engine tuned with no extra mods you can notice the difference in the car with its power.
I recommend EFI PERFORMANCE for anyone located on the Gold Coast or even Brisbane these guys not what they're doing and will give you the best possible result without ruining your engine.
EFI PERFORMANCE - unit 3/15 Emeri st stapylton (Yatala Drive-in) (07) 3801 8075
https://www.sau.com.au/forums/topic/181930-nistune/page/6/#findComment-4525540
What ECU are they using for that?
https://www.sau.com.au/forums/topic/181930-nistune/page/6/#findComment-4525622
How are peoples results using nistune for RB26s? If you are using it on your RB26 please post engine mods and results (dyno), can't see many if any in the RB26 turbo upgrade thread.
Are there any limitations when compared to other standalone ECUs (e.g. ViPEC, PFC)?
https://www.sau.com.au/forums/topic/181930-nistune/page/6/#findComment-4527160
Hi there from London ..
I have the same question ->
"What ECU are you using??"
I was told there is no Nistune for the R33GTST ..
Cheers,
Andrew
some fo the boards are interchangeable, for example on my r34gtt I believe they used the VG30 board.
https://www.sau.com.au/forums/topic/181930-nistune/page/6/#findComment-4527884
    • And if you want more power, more reliably, and cheaper, go get the Aussie RB... The 4L Barra and put that in instead.
    • No cats will keep discolouring the rear bar. Sends white paint a weird yellow stain. Cut and polish normally gets it out, but you'll be doing that every fortnight I found.
    • Both heads will be equally reliable or unreliable depending on what you do to them.  Stock the RB26 head will flow more. You have access to the stock intake ITB manifold on the RB26 cheaply which flows really well(1000hp+).   Arguably more aftermarket support for RB26, though in Aus we love our RB30 SOHC heads too.    The only downsides to the RB26 head is if you have a VL commodore and want to keep the SOHC look.  Where you may have an issue is drilling out the rb30 block for the bigger head studs but if you are building a big power motor you'd probably put bigger studs on the SOHC head too.  This is just about finding a good machine shop, sometimes easier said than done.  RB30 head worked can make big power just like a Rb26 head, so really it actually more comes down to what your preference is for your car.  People now even making billet versions of both.
    • 2630s work perfectly well. There is something to be said for just using the 30 head, as it saves all the pain of the conversion, still makes tons of power, still sounds cool, etc etc. 2630 will obviously make more power again, but the differences are not stupidly big. It really depends on whether you're racing for sheep stations or not. If it's dead serious, then it's a 26 head. If it's just for fun, it could go either way. But the 26 head and the effort to get it set up, etc etc, is part of the fun.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani Refurbed astra pump thats the cover for it in the boot I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
