the 2nd one got nicer blinkers and looks more aggressive yeah,
the only con I have is that it sticks out a bit too much
Might be just the angle of the shot, it doesn't stick out at all if you look at it in person.
it (the TS bar) actually looks restrained and more factory looking than anything else.
  • Replies 90
Posted Images
Will do.
Dont u have the Do-Luck kit R34NRG? Dont think this lip will suit/fit that kit.
yep i got the do luck kit. i would love a lip i just think it looks so much better. the original gtr do luck kit did come with a bonnet lip but it was much thinner like the nismo tune.
heres a pic
How was fitment on the kit? Almost direct fit or bad mold? Concidering getting one :)
Oh is it much longer (from top to bottom) than the stock plastic bumper?
Fitment was not perfect but was very good in aftermarket standards. Good mold, everything aligned as they should. I am quite happy with it.
From what I can remember it was an inch or so "deeper" than the factory bar. Will get some measurements for you when I get home.
that r34 looks nice! I wanted to buy a 34 but coundnt splash out the extra 3 grand...
I think the difference between a 33Gts-t & 34Gt-t is more than $3k, quite alot more comparing ones with similar mods & condition. If not u either got jibbed on ur 33 or u shoulda got the 34, much better looking inside n out and better performance.
Perthiscool - i think u may find the deciding factor could be cost, there's a big difference in cost between the 2 bars.
not really I bought my r33 GTST for 14 grand. And when I was buying there was plenty of r34 GTT's for around 17-18 grand. (I'm talking about second hand ones of course)
Edited by -=MC=- Coolio
looks hawt mate. im throwing up weather to get top secret or get east bear gtr kit... hmmm...decitions
If you could afford the east bear gtr kit then its the obvious choice. Perfect fitment plus OEM look, you can't ask for more.
Hey Guys
This East Bar lip that is pictured 6 posts up.... thats exactly what i need, any one know how i can get my hands on one?
Thanks
That east bear lip is same one as I had previously (see Post #1) Contact Powerplayimports if you want one.
How was fitment on the kit? Almost direct fit or bad mold? Concidering getting one :mellow:
Heres the measurement as promised.
Not sure of the height of the stock bumper but from what I can remember there was only about an inch difference between the two.
    • Hi Yes we're a bit optimistic we might get something out of sealing up the two pipes of the external wastegate and reactivating the stock one. I believe the orginal stock wastegate was tack welded shut. It doesn't budge and visually looks closed and sealed. The car has noticeably more lag so it could be at least part of the problem, maybe all. It's definately one of the key changes made since last tune. And it's one that's more difficult to fully understand and measure, not like for instance timing or cylinder compression.  Thanks for that feedback, we'll let you know how this progresses. Fingers crossed.   Regards Rob
    • Transplanting the vvt from a 25neo into an rb26?
    • Well, I was going to say, "Is the wastegate set up so that it is not leaking?" That's actually a different thing to what you're asking about. In theory, if you have allowed the two halves of the manifold to commmunicate (more than the stock manifold does - which is at least a little bit) then the negative effect should be apparent in delayed spool, not in outrigth power. OK, maybe just maybe, a badly set up twin scroll wastegate "crosstalk" might kill the top end, although it's hard to see how. What is happening with the original wastegate in the turbo? is it sealed off properly. If it's left flapping in the breeze, it will f**k everything up. If it is still there, and can be returned to service, I'd be capping off the external (presuming the two halves can and will be isolated from each other after doing so) and have a go with just the stock wastegate. I have an internal wastegate in my highflowed rear housing. The bigger opening and flapper should be fine to >250 rwkW. So there's not exactly a pressing reason to have the external. Done right, an external will give better results. Done wrong, it might just be possible to have worse results. Report back!
    • Hi Rob It's a nistune ecu. Yes same shop, good reputation. Apparently the computer on the dyno is compensated for temperature.    Chris was saying that the lean or richness of the mixture would be covered in the actual tune, but he's already picking up in advance that it's under what it should be. Regards the dyno, it's also noticeable on the road. But I just want to add something that has just come in, it appears there might be something in the setup of the external wastegate. In the exhaust manifold there is a centre divider between the front three and rear three cylinders. The external wastegate has a pipe from each side that join at the wastegate. Theory is those two pipes just might be pypassing that divider and introducing a problem somehow. Is anyone familiar with the divider in the exhaust manifold and the effects if the two wastegate pipes were to create a bypass path? Thanks for your questions Rob, interested in your thoughts on this external wastegate bypass theory. Regards Rob
