Hi
Did a little search and didn't get what I was after.
Has anyone used or is using a RX7 13B S5 turbo on there RB20/25 engine?
I'm curious as I don't think I have read of anyone using them.. They sell pretty cheap 2nd hand, and also high-flows go for a fairly decent price.
They are quiet a large turbo as the 13b turbo motors flow rate is roughly equivalent to a 4L piston engine.
I ask because I have a friend running one on his Falcon turbo, makes quick boost and a fair bit of power, 181rwkw on 8psi, but other than that, I haven't really seen anyone else running them except for the rotar boys.
S5 13b turbos are pretty popular once high flowed, quiet a few 13b motors running big power with them.
Any comments/feed back/experience would be appreciated.
Thanks,
Abu
https://www.sau.com.au/forums/topic/181976-13b-s5-turbo-on-rb/
There is no need to go for a 13b turbo with the price of rb20/25 turbos. They offer no benefits, are not straight bolt on. Neither are the highflows. You can get rb25 highflows for the same price as those 13b highflows.
As with all highflows, price dictates quality (generally). highflow is a word that is too easily thrown around. There can be as much variance from totally shit ---> best turbo in the world
Have you seen the precision turbos group buy? 1100 - that's a pretty damn good price for a great turbo.
Anything cheaper that you see is probably not worth your money. You'll most likely have to pull it out again, and then buy a proper turbo to do it right the second time - that'll piss you off big time.
Yeah, I have seen those.
Been keeping an eye on the group buy. Do you have to provide your own turbo to get high flowed?
Yes you do. If you like, i've got some rb25 turbos.
Do you have an rb25 turbo on your car atm? If you use mine, then that means that you'll have money left over if you sell yours - help offset the cost of the highflow (e.g. sell for 400-150 = 250 left over).
Going by this calculation, the total cost of your highflow project will be $850 :action-smiley-069:
Or if you don't have an rb25 turbo, you'll need to get one anyways
Edited by MANWHORE
Na just got a standard RB20 turbo on my car at the moment.
Will have a think about it and see how I go, depends when the group buy will take off.
i once built a rx7 turbo for my rb30det. the specs was
RX7 Rear wheel and rx7 hitachi core rebuilt
VG30 .71 rear housing machined to suit
T04 front housing and wheel
The turbo was good.. it made 240rwkw on 17psi which was good and it came on really early and strong.. i miss that earlyness goodness.
it sounded mad but i wanted more power so went for gt3540
Damn thats pretty good!
A standard S5 turbo has a 1.0 exhaust housing, a S4 on the other hand has a 0.84, from memory the fronts on both are the same, been a while since i researched it tho.
Definately worth spending a little more for a bolt on item, also remember that rotaries love boost so anyone that has paid good money for a high flow have started the boost at 15psi and wound it up from there.
    • Hey guys! Y'all are the masters so figured I'd check in on a few items here. - My engine sounds ever-so-slightly more raspy than the other NA RB25s I've listened to. It's barely noticeable but definitely a slightly different sound. - When I back off the throttle at high RPM, I will sometimes get a pop out of the exhaust, assuming this can be diagnosed as misfire. Some history on the car: - Had an exhaust leak in auction sheet but was claimed to be fixed by seller (bought from USA importer).  - Car's coil packs and sparks were replaced when it was sold to me, but unsure on what the gap is and whether the coil packs are correct.  - A prior mechanic had misdiagnosed a pilot or throwout bearing sound as LSPI/detonation. Had played with timing a bit, pops/raspy sound of engine just got worse. Got timing reset. - Had failed emissions a few times. First time went in as is, failed. Second time, replaced cat, still failed, running rich as hell. Third time replaced o2 sensor, passed. Car still smells gassy though. - Timing belt and valve cover gasket also replaced.  - Gas mileage is... low. about 350-400K per tank.  Any idea if I'm having any serious issues here or does this all sound like normal old NA RB stuff and I'm fine to drive it with the pops/slightly raspy engine? If it'll help, I can get drop a video of the sound of the engine.
    • So....to find any R chassis part number, get your VIN (will be something like ER33-xxxxxx for you) and go to: https://www.amayama.com/en/genuine-catalogs/nissan and enter it. From there you have access to a web version of Nissan's part system, FAST. It is a bit tricky to get used to, so maybe have a shot and post up what you think.  You can also search by general model but note in some cases your car might have different options so VIN is safest.  On diagram 211 I got 14075-75T16 for Connector, Water Hose If I search for part 14053‑21U10 that you posted, that is also a water hose but not the one bolted to the plenum and 14075‑04U00 is the fitting where the water hose goes into the block.
    • Yeah now we are talking I much prefer coolers in the front middle because it lessens the chance of a small bump to a corner stopping the whole event. I was thinking the AT cooler can move out of the radiator, delete the AT/engine coolant interwarmer and mount a separate cooler with a thermoswitch somewhere further back as is common in racing, that would be one thing. Beyond that, the engine oil cooler is an obvious one to move to the wheel arch, potentially one on each side, but unused space is an issue. I did have a earlier pic with the bumper off but it doesn't show how busy the corners are: DS is full of the auto driving sensors and PS is totally fully of windscreen washer fluid reservoir But ultimately I was hoping to keep the AC, and the water/air heat exchanger is fundamental so it is not just the radiator that needs to be in front BTW here's airflow to the rad as it ran at the track (one horn is gone now and I'll remove the lights next time):
    • your right the maps for Australia came out in 2017 but are 2010 maps. i got the updated maps SD card put it in and it was the same. Same maps in my Brothers Nissan Patrol. 2020 i think his car is
