Alarm Question
AFTDRK
 Share
Hey guys,
just a couple of quick newbie questions about alarm systems with turbo timers inbuilt, are they any good ? how does the system judge how long the car should remain on for, im assuming its fully automatic ? im planning on getting this alarm system http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...type=osi_widget (i know i know Ebay alarms arent heavily favoured by you guys etc im sorry! besides my car is never far from me - will always be kept in my carport) also can i get an idea of how much such a system would cost to be fully installed into my 33,
thanks alot guys any information would be greatly appreciated as this is my first import and im a big newbie,
P.A
My Autowatch alarm has the inbuilt turbo timer. If your car only runs for 2-3 minutes, it will not use the turbo timer and the engine will shut down immediately. If the car runs for longer, the turbo timer counts down for a preset time (i think mine is set to 90 seconds). This works fine for me, i choose to go for an alarm with the t/timer in it, to reduce the amount of unnecessary wiring + electronics in my car.
you may not have much $$ left after your purchase but I would honestly NOT buy that unit. since you are in adelaide go see adelaide pro sound and get him to sort the car out. it will be done properly AND it will be insurance compliant. that one will last 6 months tops and IF you need a remote where are you going to get one from??
These alarm have crappy protection. Remotes so fragile....and the I dont recommend the engine start in your car. Sometime the sense is faulty and your forget car in gear ......hope nothing front of the car. -.- I took down my Fence down once.....
 Share
    • As far as I know, Infiniti stopped importing vehicles before 2020, even though they were still selling their stock for at least a year or 2 after that, they were older build years, therefore, you can import a 2020 400R, because you couldn't buy an AuDM 2020 built Q50 RS. As for insurance, you might need to go through one of the enthusiast insurance companies, they tend to insure a lot more grey import models than the mainstream insurers as Duncan mentioned.
    • loved seeing the zenvo on the a1 just after the hatfield tunnel i was the guy in the white van trying to egg you on it sounded awesome and those exhausts glowing red inside insane cheers for the thumbs up tim and tom.
    • So.... when I'm finally getting around to having my power steering leak sorted, now it looks like I've got the same issue most A/T Skylines are having. My A/T light will randomly come on and I'm stuck in 3rd gear until I turn the car off and on again. Only 3 weeks ago I did a complete transmission service: Oil flush + new gasket + new filter. This came out of nowhere!! It wasn't like the car was driven hard. I drove about 3 mins down the road to get fuel and boom!!!  Anyway, I have a few questions and hope you fine people can help me out here. All questions are in red. 1. The solenoids: I was looking at the parts catalogue in Amayama and I could only find the Solenoids as an assembly. https://www.amayama.com/en/part/nissan/319404ax05 I read in another thread that Solenoid A = 31940-4AX02 & Solenoid B = 31940-4AX05 but the Amayama product has only the code of B. Is this the right part? Can anyone who has done the Solenoid changes or seen them confirm if this is the complete set of A & B?   2. Gasket and Filter: I'm not going to try change the solenoids myself because it seems difficult to do in a home garage with just 2 jack stands. I plan to take it to a shop and get it changed. I was also going to buy the transmission sump gasket at the same time so I don't reuse the same gasket. Should I just use the existing gasket as it has only been on the car since OCT 19th? (~3 weeks) Should I be buying a brand-new gasket and a filter? Does this job involve taking the filter out?   Thanks in advance to everyone. It's hard to find a video of someone doing a solenoid change on a R34 so any help you can give answering my remaining questions would make me less stressed.
    • Yea - From what I have seen from the video, the car idles like any R34 lol 50PSI of fuel pressure is hardly super abnormal, the regulator is working because the pressure remains static when the throttle gets revved, i.e pressure remains the same when manifold vaccuum changes. Bigger pumps on stock rails always bumped the pressure in the rail without using an aftermarket regulator to change that. Do you know what your IAC is actually doing? Has there been any data showing the stepper motor % etc? There's no way your idle is actually moving around the way the cluster(s) are indicating. You would hear the difference with the engine RPM flying to 3k and 1k in mere seconds. I'd be checking the wiring to the tacho. What the tacho is telling you and what the engine/ecu is telling you are different things. I assume your ECU doesn't display the spike. So whatever is telling the tacho to be at X rpm is doing something weird. When the going gets insane, you're on the wrong path. You've ruled out plenty of things that are working correctly/aren't the issue. Your idle isn't doing what the tacho is indicating. You have two seperate issues, I don't think they are linked, and the idle seems reasonably okay unless it's stalling which.. well, it hasn't. Troubleshoot the stall if it occurs by figuring out what your IAC is doing vs what it is being told to do.
    • So awesome! I love the RB with the exhaust on display.
