hey guys did a search in the vic section and found threads about this for early 2006 nothing recent.
well i called up RE customs today and got quoted $800 to get the timing belt and water pump done. seems a little steep but what are you guys paying these days???
got quoted for a gates blue timing belts and all bearings and seals to be replaced and got told while the front end is out might as well to the water pump which is fine by me but $800 is a tad to high.
can anyone recomend me other places to try???
im in rowville SE suburbs and work in the city so any where close to the city or SE side is all good.
thanks
Ash
https://www.sau.com.au/forums/topic/182026-timing-belt-and-water-pump/
any decent mechanic can do this for you... but its isn't a quick job its a MAJOR service so I don't know if you will get any cheaper quotes... considering the parts will cost you almost $400 and it sounds like they are going to service your pulley bearings its not a bad deal
... small price to pay versus a timing belt or water pump failure... even a basic rebuild/freshen up will cost you over 4 grand
Yep would agree, a lot of parts used and labor also, sounds about spot on :P It's a major service, how many K's you at? Have you considered doing -
New Spark Plugs
New drive belts
New Oil Filter
New Fuel Filter
New Cam and crank seals - done with the idle bearings
Gearbox oil
Engine oil
Diff oil
Radiator and engine flush
Cleaning\replacing air filter
New Spark Plugs
New drive belts
New Oil Filter
New Fuel Filter
Gearbox oil
Engine oil
Diff oil
atm im on 103000ks
im only getting the timing belt and water pump done professional
the rest i can do my self which will be done in 2 weeks when the next service is due
New Spark Plugs- will do my self
New drive belts- what do u mean by drive belts??? what does this run
New Oil Filter-will do my self
New Fuel Filter- will do my self
New Cam and crank seals - done with the idle bearings- will be done with timing belt
Gearbox oil-will do my self
Engine oil- will do my self
Diff oil- will do my self
Radiator and engine flush- radiator already been flushed did it last week and engine will be done when oil is changed it 2 weeks
Cleaning\replacing air filter- done
You can do most yourself, but still doesn't change the fact everything has to come out to get to the Water Pump.
And then all the drive belts, idler/tension bearings etc.
All must be changed.
$800 is pretty reasonable for this in '07
im a mechanic an have done this to my car myself (no im not offering to do yours :rolleyes:...lol...)
I reckon $800 including a new water pump is a good price (your coolant flush was a bit of a waste when it'll all be drained out to change the water pump...but oh well), its about 4 hours labour for all of that so theres about $350-$400 there depending on labour rate itself. An parts would be about $400 as well id say
gates blue belts around $110-$130
tensioner & idler pulleys + new bolt around $130-$150
crank & cam seals around $30-$50
Water pump around $130-$150
few litres of coolant & bleeding up your cooling system around $50 - $70 (depends on what brand/type used)
so going on the higher side of my guesstamation.....theres $550 right there without the labour of changing it all, if they have a cheap labour rate of around the $350 for the 4 hours. Theres you $800 right there, which is a good price if you ask me, go with it.
hope thats of some help. Cheers
ash,
get RE to do the work. i know 800 is a bit more than u expected to pay but, if it saves u 4g for a rebuild, i think its worth it.
also ud hate for your car to go boom from over heating on the GOR cruise...lol
ash,
lol true
thanks guys
ye will be giving it to them to get the work done. juts wanted to get some opinions before i jumped for it.
spanks :D
but they said they were pretty booked for the next 2 weeks so will be taking it easy on the GOR
