Thats not too bad (in terms of the weather).. If its ok and not too bad, we'll do twisties.. But I think we'll decide when we're all at P6, and go with how the weather is feeling, as to whether we do twisties or the highway.. Hey I have always wanted to do one thing though.. A lap of burwood.. Imagine all the skylines through there??!!! LOLLLLL
Speak to you's tonight! =)
Nathanial, I'll see you at 6pm as discussed, to wax the cars.. Tomorrow morning we'll put the ribbons on for the wedding...
No wokkas .. Btw im fixing my old rims they are looking f**kn pimp exactly like stock..
6pm is right .. ill be there earlier n get to work on my car slightly early because it often takes in excess of 1 hour to do the full wax and well have to double up on yours ..
And yeah chris ill be able to pick you up.. You know what you should catch the train to burwood station instead .. easier for me to get your from where im doing the cars.
Was a good drive.. Stupid move drifting around the roundabout in front of maccas at fairy meadows.. If only the roads weren't wet. Oh well, cop it on the chin. We'll organise another one soon.. Im going up to mittagong & bowral (1 hr and a half away, towards goulburn) this saturday if anyone would like to go for a drive.. Leaving around 10am.. ?
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
