Hey guys,
I have done a few searches on this and have found out some info but am confused by some aswell, Through a twisted chain of events my r32 GTR has got a standard 4.11.... diff in the rear, and now as (completely installed) what appears to be a 4.364 diff in the front. NOT GOOD!
We are not exactly sure which diff it is in the front but from turning the shaft and counting rotations that what mechanic estimated it to be, around that.
What I was wondering is
1. Rather then change the fron diff, should I just leave it, and replace the rear.
1a. is there many compliactions with doing this????
2. Is it possible to switch the front diff without ripping engine out???
3. If the mechanic reckons the front diff ratio is around the 4.5 mark is there any other ratio diffs that it could be, regardless I he is gonna get in and have a look on the crown wheel, I'm just trying to see if I can start trying to source a new front or rear
If anyone has got an incite into this problem that would be a great help,
cheers guys
AsH
https://www.sau.com.au/forums/topic/182041-gtr-diff-questionz/
you really need to get in there and find out what the exact ratio is of the front diff. a common swap is GTS4 diff which is 35:8. if this is what you have in the front then I would suggest hunt down a GTS4 rear diff and use that crown wheel and pinion with your current GTR centre in the rear. then you'll have the same GTS4 ratios front to rear. if it is actually 4.364:1 I have no idea what it could be out of. I can't even think of a CW/Pinion combo that would give a ratio of 4.364. I would say it's most likely the GTS4 diff he just did some bad maths. :P
If i remember right the 4.3 final is the same final they used in the GROUP A GTR in japan, i've seen a few for sale on yahoo label nismo group a or nismo n1
group A cars used lots of different ratios all custom. they may have used a 4.3 for some tracks, but again I don't know what Crown wheel/pinion combo would give an exact 4.3 ratio.
  • 1 year later...
ok..
Im re-hashing an old thread so as I dont have to start a new one.
I have an R32 GTS4 standard diff - 4.375 Diff ratio - Yes?
And is this an open diff?
Now, Im using it for drifting and im looking for a a cheap LSD.
An R32 GTR is a mechanical 2 way. Yes?
4.111 diff ratio - Yes?
Now, R200 refers to the crown wheel - 200mm - Yes?
Is an R200 diff a GTR diff?
What is the name of a GTR (Non - Vspec) LSD Diff?
Could I get a GTR diff center and drop into my housing?
Edited by GTS4WD
Using google for "r200 GTR diff" I found some results and this site: http://forums.nicoclub.com/zerothread/243052 advises the casing's are different
All I found was "R200" diff and that its the shortnose version...
    • Oof, I will forevermore have those shredded gears in mind whenever someone talks about showing mechanical sympathy towards their car. Thanks for the photos, fascinating stuff!
    • Curious to see how the SpeedTek stuff holds up
    • The holdups last year were drivetrain related. I had the car out right after getting the bearing issue resolved. Third launch and the car didn't move after releasing the clutch. It had sheared all the engagement teeth off the 1st gear.    Thankfully no other damage was done. I set an aftermarket gear beside an OEM gear and found that the engagement teeth on the OEM gear were much larger and better supported. Looking through my bin of spare transmission gears I found that there are two types of tooth on the OEM first gears - the larger tooth and the smaller tooth. It looks like most aftermarket gearset manufacturers base their design on the smaller tooth. OEM large tooth left - Speedtek, OS Giken, etc or OEM small tooth right Decided to give that larger engagement tooth a try. Pressed the ring off an OEM gear and sent it to a transmission manufacturer here in the States. They did their "faceplating" operation with my synchro ring on the Speedtek gear.   I reassembled it, took it back to the track and promptly destroyed the gear itself.  I'll rebuild this and use it as a spare - thankfully just first gear and the countershaft are damaged beyond repair. Definitely disheartening but my welded on engagement tooth ring held up!  Moved to Speedtek's dog engagement design as the gears appear to be much stronger. So far they have taken much more abuse at the track. Also scored a Stillway lockout from the Netherands for super cheap. It's for some other RB transmission so it took a bit of fabrication to fit but honestly a very easy job. I also had to heavily modify the gates as they were very different.   Then for some reason at the last test and tune a silicon coupler below the throttle blew off and took out the radiator and fan. Thankfully it was in the burnout box and not down track. This car is really beating me up - I still haven't made a pass in it. Ran it through the gears many times on the street but it keeps biting me at the track.  Currently in the process of replacing the radiator and remaking the throttle pipe to remove the coupler and use a cast 90 and a vband. I WILL get this thing down the track...
    • Covers most of the above points really. There's a few exceptions but most just see driving as an irritating but necessary task they must complete if they want to get anywhere on time. Also see it as a good time to show their awesome multi-tasking abilities on their mobile and/or doing their makeup.
    • I don't believe I posted pictures of the second oil pump pickup I added so here they are. Data shows it gets oil pressure up to the relief pressure much earlier in the RPM. Is that important? Not likely... This was just another attempt to fix the bearing issues.   I also heavily opened up the inlet to the pump since it now had to flow oil from two pickups. I believe the diameter increased about 1/8".
