hey Vince .. i checked with Reddevil slacks creek they are different R34 fans are diffetn locations to 33 ones.. and 34 ones are taller then 33 items they make their own custom ones for 500 bucks stainless steel top and end tanks.. maybe do a group buy ?
https://www.sau.com.au/forums/topic/182077-r34-radiator/#findComment-3306705
Triple Core Cooling Pro radiators from Just Jap bolt straight into the R34GTT; couple of us running these on the forum... only mod required is to block off one of the holes as the NEO does not have a sensor like the R33GTR (oh forgot to mention it's the R33GTR one that fits)
Works well too!
https://www.sau.com.au/forums/topic/182077-r34-radiator/#findComment-3306730
How large? Direct fit?
What car?
Had spoken to them, the alloy rad is wider than the stock rad (duo core).. and according to them, it will be direct bolts on. They have R32, R33 and R34 rad in stock and willing to do a better price for us if we do a group buy.. :3some:
For R34 GTT, will need to plug off the temp sensor inlet.. :D
https://www.sau.com.au/forums/topic/182077-r34-radiator/#findComment-3310731
what is the thickness vince.. with a RB engine in a sil i have like .5cm of distance between engine/coolerpiping/radiator.
Not sure bud...but definitely thicker than the stock. Will pm u the details and u can go and have a look.
https://www.sau.com.au/forums/topic/182077-r34-radiator/#findComment-3326021
    • I have done smoke test and can’t see any leak on high or low side.   checked pump and fluid can flow through. Removed the high pressure from steering and did smoke test and same on low side, no leak.   puzzled. Thinking why if it was all ok it suddenly went as car was off road for a year. Don’t want to disassemble pump yet as i can see fluid / air( compressor) can flow through with no issues
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
