Mine idles as a5h said too, revs really high until it warms up.
My car was running really sluggishly (had been since I bought it and no one could find the problem), we changed the plugs and cleaned the throttle body, which mind u, was caked with black sludgy crap and its idled higher and lost its flat spot since then!
It may have made a little bit of a difference when u cleaned the throttle body out..?
https://www.sau.com.au/forums/topic/18212-idle/#findComment-385337
Well I have checked the ecu codes, and disconnected the battery to no avail. The ecu came up with code 55; admittedly it was after i disconnected the battery and drove it for two days with the same problem. I did notice the vacuum hose coming off my aftermarket BOV was slightly cracked, so started wondering if this was the cause of the problems? Any thoughts????
I have also checked the TPS, 0 ohms result, and the AAC valve had continuity.
I remember seeing how to adjust the idle via the ecu, but I cant remember where I saw it?? Anyone know of this????
The only other thing I can think of doing is adjusting the AAC valve screw, but Im worried it will alter the air/fuel mixture to its detriment, even though it only controls the air flow.
Any help greatly appreciated.
https://www.sau.com.au/forums/topic/18212-idle/#findComment-398022
Its supposed to idle high when the engine's cold.
There's a screw on the back of the ECU - you have to remove the ECU to get at it. But its for very fine adjustments.
Adjust the AAC screw, it won't affect the A/F ratio - its only effective at idle, it allows air to bypass the (closed) throttle.
https://www.sau.com.au/forums/topic/18212-idle/#findComment-398589
This is normal to idle at around 1500rpm when cold then to drop around 650-800 is okay anything higher should be checked... They all do this, they are meant to. Its programmed in them to warm the engine and get the oil flowing better on startup cos of the turbo, rather than having to wait for the car to warm itself over a longer time thsi helps it get things rolling.
https://www.sau.com.au/forums/topic/18212-idle/#findComment-403559
That's right. There are a lot of cars that act the same way. It warms the car up faster. You should not give a turbo car heaps when it is cold (any car for that matter). :burnout:
https://www.sau.com.au/forums/topic/18212-idle/#findComment-404578
After much deliberation, I adjusted the screw on the AAC Valve, to no avail. It only dropped a couple of hundred revs. I then decided to pull off the whole air regulator with the AAC Valve on it, to find that the AAC is stuck partially open in its unmounted state, (but still bolted to the air regulator.) I put 12v to it, and it didnt work as it should,(contracting the inner pin), and even after plugging it straight onto the end of the wiring loom, it still did nothing. I figure this is what is causing the high idle. Does anyone agree with my theory??
Thanks in advance.
Just as a matter of interest. my mates manual 33 idles at 1000 rpm cold and drops to around 700-800rpm once warm.
https://www.sau.com.au/forums/topic/18212-idle/#findComment-411892
I did adjust it with plug disconnected, with above results, which is why I pulled it off again. I cleaned it with carby cleaner intially, hence the above problems. It only had a small amount of carbon in there & the throttle body BTW.
Any other thoughts???
https://www.sau.com.au/forums/topic/18212-idle/#findComment-413658
I have since swapped the whole AAC valve assembly with my mates, whose car idles at a respectable 1000rpm cold. This did not change anything at all on my car. I have been told it could be the TPS, even though it measured 0 ohms, the variable resistor may need to be readjusted. Anyone one else done this before on a Series 1 33??
Thanks in advance!!
https://www.sau.com.au/forums/topic/18212-idle/#findComment-430538
Hi Guys,
Hoping you could help with my problem also. I know high idle at start is normal, but can somebody please explain this. Drove home tonight, and once I pulled into the driveway, in idle, the tacho constantly fluctuated between 800 and 600 rpm. just back and forth. Should I be concerned?
Thanks guys
https://www.sau.com.au/forums/topic/18212-idle/#findComment-431234
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
    • I had the same previously, and it really shits me. They just run off red book averages or whatever as the maximum insured, there are never good quality cars available to buy for anywhere near those prices. I don't even understand why they do it. Sure having a customer overinsure then false claim is a risk, but how often does that really happen in the world, 1%? 0.1%? On the other hand, all 10-20% above redbook listed prices and charge 10-20% higher premium, surely that is more profitable for those cockroaches
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
